Hello
I am new with octoprint, and has searched for config with wired network.
The setup with wifi was basically straight forward, but I would like to use it wired. What is the proper Way?
Can I keep the wif configi, and make i autoprioritize a wired connection, or β¦?
Br
Jesper
To use your Pi wired, plug the ethernet cable in to the Pi and that's job done.
To disable connecting to the wifi, you will have to remove/comment out the configuration.
Hi
Thanks for your reply.
If powered up using wifi, will it switch to wired automatically when connected?
Br
Jesper
I can't test it right now on a Pi - but on my laptop (which is also running Debian) it switches to wired as soon as it has been plugged in. It even works in the middle of a download.
You can still reach it via wifi, but the laptop uses wired for all connections.
I'm pretty sure it's the same on a Pi.
