I have a Creality LD-002R connected to a Raspberry PI 3b+ with octoprint 1.8.6, octopi 0.18.0. I have a male-male USB-A cable connecting the printer's USB port to the PI.
i can do almost everything, upload, move the z axis, see/control USB webcam but I can't get octopi to create the virtual-sd-card-over-usb. I've loaded the chituboard plugin and because this printer reports back as the " CBD made it," i have that plugin added as well. i have no other plugins installed.
When I try to initialize the sd card, nothing happens. When I try to upload to the sd card, I get the following:
2023-01-19 16:30:08,322 - octoprint.filemanager.analysis - INFO - Starting analysis of local:beta dice set + 2d6.ctb
2023-01-19 16:30:08,366 - octoprint - ERROR - Exception on /api/files/sdcard [POST]
File "/home/piupiu/oprint/lib/python3.7/site-packages/flask/app.py", line 2073, in wsgi_app
response = self.full_dispatch_request()
File "/home/piupiu/oprint/lib/python3.7/site-packages/flask/app.py", line 1519, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/home/piupiu/oprint/lib/python3.7/site-packages/flask/app.py", line 1517, in full_dispatch_request
rv = self.dispatch_request()
File "/home/piupiu/oprint/lib/python3.7/site-packages/flask/app.py", line 1503, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**req.view_args)
File "/home/piupiu/oprint/lib/python3.7/site-packages/octoprint/server/util/flask.py", line 1598, in decorated_view
return func(*args, **kwargs)
File "/home/piupiu/oprint/lib/python3.7/site-packages/octoprint/vendor/flask_principal.py", line 199, in _decorated
rv = f(*args, **kw)
File "/home/piupiu/oprint/lib/python3.7/site-packages/octoprint/server/api/files.py", line 681, in uploadGcodeFile
target,
File "/home/piupiu/oprint/lib/python3.7/site-packages/octoprint/server/api/files.py", line 639, in fileProcessingFinished
tags={"source:api", "api:files.sd"},
File "/home/piupiu/oprint/lib/python3.7/site-packages/octoprint_chituboard/sla_printer.py", line 438, in add_sd_file
on_success()
TypeError: selectAndOrPrint() missing 3 required positional arguments: 'filename', 'absFilename', and 'destination'
2023-01-19 16:30:28,142 - octoprint.filemanager.analysis - INFO - Analysis of entry local:beta dice set + 2d6.ctb finished, needed 19.82s
When I try to print a file, I get this error:
Send: M23 beta dice set + 2d6.ctb
Recv: //Disk init fail!
Recv: //############sd_mounted Error! cann't open file !
Recv: ok N:79 Send: M4000 Recv: ok B:159/0 E1:157/0 E2:155/0 X:0.000 Y:0.000 Z:1.000 F:0/256 D:0/0/0 T:0 Repl: ok T:0 /0 B:159 /0 E1:157/0 E2:155/0 X:0.000 Y:0.000 Z:1.000 F:0/256 D:0/0/0 T:0
Thanks in advance for your help.
