Raspberry 4b no longer appears to boot
I am sure it is completely circumstance but wanted to post and see if others have experienced any issues. I decided to do the re-image to 1.0 of OctoPi. So I built my image, everything looked good, put the SD into my PI and powered it on. Nothing came up on the network either on wired or wireless. I connected it to a micro HDMI to HDMI and tried to see what was going on. I have no video output either. The red light on the Pi is red and steady. I am using the factory power supply from the kit from RAKWireless so not using some janky power supply.
I used two different SD cards, two different machines to build the image and nothing boots. I get no video either. I tried flashing just straight Pi not OctoPi and still nothing and no video.
Tried the yaml safe mode option since there is no boot or video
This did not solve the issue.
I tried to find something on getting the bundle if the device does not appear to boot. Would be open for assistance here.
The device worked just fine with 0.86 (I believe that was the version). Thought about trying to boot that version but it was not available with the RasperryPi Image installer, just the 1.0 version. I pulled the heatsink case off of the Pi and didn't see any type of physical damage that was visible.
Does the green LED flash at all? If not, then either the SD socket is bad or the pi itself is bad. Red means it has power. Green will flash to show it sees and is accessing the SD card
I have no green light. I have contacted the distributor. Thanks for the feedback. I was hoping for some magical answer. :wink:
