I'm tying to set up control for two of my printers over the UART pins on the Raspberry Pi 3 and having some errors.
Connecting to: /dev/ttyS0
Changing monitoring state from 'Offline' to 'Error: Connection error, see Terminal tab'
Unexpected error while connecting to serial port: /dev/ttyS0 error: '(22, 'Invalid argument')' @ comm.py:_openSerial:1931 (hook default)
Inintially I was trying to connect via ttyAMA0 (which is no longer allocated to the UART pins 14/15)
I also needed to set proper permissions on the correct tty (ttyS0) which is no longer giving a permissions error, however now it's showing the above error.
I tried switching between baud rates (uploading different settings to the firmware and changing octoprint settings), 115200. 230400, 250000.
Testing on two boards: Ramps 1.6 (SMD version of RAMPS 1.4), and MKS Gen L 1.0
Firmware: Marlin 1.1.8
Octopi 0.14.0
OctoPrint 1.3.6
error: (22, 'Invalid argument')
2018-03-20 21:24:03,575 - octoprint.plugins.filamentreload - INFO - Error: Disabling filament sensor.
2018-03-20 21:24:03,578 - octoprint.plugin - ERROR - Error while calling plugin filamentreload
File "/home/pi/oprint/local/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugin/__init__.py", line 225, in call_plugin
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filamentreload/__init__.py", line 113, in on_event
GPIO.remove_event_detect(self.pin)
RuntimeError: Please set pin numbering mode using GPIO.setmode(GPIO.BOARD) or GPIO.setmode(GPIO.BCM)
2018-03-20 21:24:06,662 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-03-20 21:24:10,531 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-03-20 21:24:15,454 - octoprint.util.comm - ERROR - Unexpected error while connecting to serial port: /dev/ttyS0 error: '(22, 'Invalid argument')' @ comm.py:_openSerial:1931 (hook default)
File "/home/pi/oprint/local/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/util/comm.py", line 1931, in _openSerial
serial_obj = factory(self, self._port, self._baudrate, settings().getFloat(["serial", "timeout", "connection"]))
File "/home/pi/oprint/local/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/util/comm.py", line 1921, in default
serial_obj = serial.Serial(str(port), baudrate, timeout=read_timeout, writeTimeout=10000, parity=serial.PARITY_ODD)
File "build/bdist.linux-armv7l/egg/serial/serialutil.py", line 282, in __init__
self.open()
File "build/bdist.linux-armv7l/egg/serial/serialposix.py", line 296, in open
self._reconfigurePort()
File "build/bdist.linux-armv7l/egg/serial/serialposix.py", line 427, in _reconfigurePort
termios.tcsetattr(self.fd, TERMIOS.TCSANOW, [iflag, oflag, cflag, lflag, ispeed, ospeed, cc])
2018-03-20 21:24:15,763 - octoprint.plugins.filamentreload - INFO - Error: Disabling filament sensor.
2018-03-20 21:24:15,765 - octoprint.plugin - ERROR - Error while calling plugin filamentreload
