So, I recently got a 5" hdmi touch screen from amazon to use with my raspberry pi thats running octoprint, utilizing the TouchUI plugin.
But for some reason, whatever I do, octoprint/touchui is only using a quarter of the screen.
Its the same at boot with "splash" console, only using that upper right part.
I´ve gone through all the settings, followed the manufacturers "guide" to setup the screen within /boot/config.txt but nothing resolves it.
The screen is a 5" 800x480, but octoprint/touchui treats it like its a 1920x1080 display, because if I change the resolution to 1920x1080 it "almost" fills the entire screen, but everything is unusable.
Here is a really bad pic of what the screen looks like. (see past the login promt, I had it "working" a minute ago, but messing around with stuff gave me this and I gave up)
I´ve tried googling this for the past couple of hours without any luck, so if anyone has encountered this and/or has a fix, I´m in you debt!
(If any words are spelled wrong or I used some phrase wrong, I´m swedish)
Following lcdwiki.com guide for 5" hdmi-b display
Octoprint v1.7.2, Latest Octopi, Ender 3 v2, Jyers v2.0.1
