Raspberry pi 4 OctoPrint 1.0.0-1.10.0 micro steps after latest update
after the latest OctoPrint update I get only micro steps when I want extract or retract filament.
here are my hard en software setting:
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1500.0
env.hardware.ram: 3837739008
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.1
env.plugins.pi_support.octopi_camera_stack: camera-streamer
env.plugins.pi_support.octopi_version: 1.0.0
env.plugins.pi_support.octopiuptodate_build: 1.0.0-1.10.0-20240425103001
env.plugins.pi_support.octopiuptodate_build_short: 2024.04.25.103001
env.python.pip: 24.1
env.python.version: 3.9.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2024-05-27T13:32:31Z
octoprint.last_safe_mode.reason: settings
octoprint.safe_mode: False
octoprint.version: 1.10.2
printer.firmware: Marlin 2.0.9.7 (May 24 2024 20:02:24)
systeminfo.generated: 2024-06-25T07:45:48Z
systeminfo.generator: zipapi
The template you deleted right away (what's so fancy about deleting the template?) asked for the systeminfo bundle.
Pleas attach it to your next post.
octoprint-systeminfo-20240625101538.zip (147.4 KB)
sorry I'm a newbeee
i reboot in safemode and still had the same problem
Your Feedrate on the extrusion commands is F25 - that's 25mm per minute...
Mine is F300. Go to the Settings(the wrench)->Printer->Starred Printer->Edit(the pancil)
Then Axes and check your numbers (I use 6000 on X and Y, 200 on Z and 300 on E).
thank you very much!!
I have the ANet A6 v1.7
