I'm the new one I've been trying for weeks now to get my webcam on my Raspberry 4 to work. Without success. The problem: the snapshot of the camera is displayed, but not the stream. I give up and therefore turn to you
My webcam is: MakerHawk night vision camera with 5 MP and OV5647 chip.
Exactly it is this one:
I have been the owner of a Creality CR-10 v3 and and Raspi 4 since 11/2021, so for a short time and had no experience with Linux until then. However, after hours of reading forum posts, I got a bit into it. I've turned a lot on the screws for the settings, but nothing has worked. What am I doing wrong?
I downloaded the current image here and installed it according to the numerous instructions available on the Internet.
Image downloaded here
Written to a Sandisk extreme 32GB MicroSD with rufus
Raspi is in my LAN with a fixed IP of 192.168.1.7, so no WLAN configuration
Login to the raspi with PuTTY and change the password, sudo get update / upgrade and activate the camera in the config with sudo raspi-config
Start and initial setup of the Octopi web interface
I haven't changed anything in the webcam settings in Octopi, with the address octopi.local/webcam/ there is a snapshot of the camera but the stream doesn't work.
Is there anything in the browser console when you open that page with the stream/snapshot displayed? Any errors might give you a clue as to what is going on there. The webcam log in your systeminfo bundle makes it seem like everything is going OK.
I haven't changed or added anything. The same computer only that and the Raspi were switched off for 3 days ;-))))
I almost don't believe it myself...
Hopefully it stays that way now. Not that the stream stops working the next time you turn it off.
One last piece of information:
I had switched off the printer in the meantime because the fan noise bothered me and the Raspi stayed on. When I then turned the printer back on, the stream was again unavailable. The stream was only available if I restarted the Raspi at the same time as the printer. Maybe this was the whole problem...
