Camera model, raspberry pi Camera V2
**I can seem to be able to see the camera after running the lsusb command
pi@octopi:/ $ sudo apt-get install fswebcam
Reading package lists... Done
Building dependency tree
Reading state information... Done
fswebcam is already the newest version (20140113-2).
0 upgraded, 0 newly installed, 0 to remove and 157 not upgraded.
pi@octopi:/var/log $ lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
- I have ran the raspi-config and enabled both the camera and the I2C . Make note that I am not plugged into my printer via usb. Just have the pi online and reachable.?**
Logs (/var/log/webcamd.log, syslog, dmesg, ... **[ 4.402922] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.416108] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 4.441704] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.441742] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.444754] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.444783] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.448332] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.448368] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.216435] uart-pl011 fe201000.serial: no DMA platform data
[ 6.242209] random: crng init done
[ 6.242223] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.322740] 8021q: 802.1Q VLAN Support v1.8
[ 6.420648] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 6.613264] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.613336] brcmfmac: power management disabled
[ 6.849547] bcmgenet: Skipping UMAC reset
Additional information about your setup (OctoPrint version : 1.3.12
OctoPi version : 0.17.0 .)
