Raspberry Pi Camera V2
Octopi isn't showing the camera at all, no matter what I do.
I have tried 3 different Raspi Cam V2 modules, on two different Raspberry Pis (one 3, one 4) running Octopi. I've reseated the cables multiple times. Tried multiple different ribbon cables (including the ones that came with the cameras). Toggled camera support on and off multiple times. Rebooted what feels like 2700 times. Checked, double checked, triple checked that I'm connecting to the camera port, and inserting the cable the correct way (blue side facing the USB/Ethernet edge, contacts facing toward the status LEDs). No matter what I do, none of these are detected. Considering I've eliminated the other variables, it seems like the problem is with Octopi itself.
pi@ender3:~ $ sudo vcgencmd get_camera
supported=1 detected=0
This is always what I get.
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video10
/root/bin/webcamd: line 184: printf: 0x: invalid hex number
<13>Apr 15 19:24:30 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video10
i: Using V4L2 device.: /dev/video10
i: Frames Per Second.: 10
i: Format............: JPEG
Error opening device /dev/video10: video capture not supported.
i: init_VideoIn failed
Goodbye...
Raspberry Pi 4 B
Raspberry Pi 3 B+
OctoPrint: 1.5.3
OctoPi: 0.18.0
This has been solved with help from people in Discord. If anyone else encounters this issue, there's a second ribbon cable connecting the image sensor to the board. It's very tiny and it pops off if you so much as look at it wrong.
