Raspberry Pi Cam V2 (V2.1 8MP) The webcam server is currently not running
Raspberry Pi Cam V2.1
The webcam server is currently not running after change the Resolution to camera_raspi_options="-x 3280 -y 2464 -fps 15" in /boot/octopi.txt
set an lower reselution solves the Problem?
(i also setup octopi 0.17 new up
There ist no /var/log/webcamd.log
OctoPi 0.17.0 (try new install yesterday)
OctoPrint 1.5.2
Raspberry Pi 3 Model B Plus Rev 1.3
the max resolution is 1080p30
Hi i think not so? What are the best settings with an very good quality? I thin Nativ schould be fine?
mhmm I thought those were for just for stills
try to increase you gpu memory in the raspi-config
Should be sudo raspi-config, then Advanced Options, then Memory Split in the shell
Try 192MB or 256MB
Grab the log from running journalctl -u webcamd if it isn't there, there's a bug that prevented it from being written in that version of OctoPi.
Ok i have give the gpu more memory but i think it ist to mutch resolution. On my phone (wlan) the video now is laggy. Did somebody know an good resolution?
