Raspberry Pi Camera Module 3 (imx708)
My Camera is recognized by the OS, but OctoPrint is not able to connect to it. I suspect this is a configuration issue, but I'm struggling to find the information that will show me what I need to do.
When I run libcamera-hello I get the following;
Libcamera Output
[10:36:30.061883897] [3037] INFO Camera camera_manager.cpp:299 libcamera v0.0.4+22-923f5d70
[10:36:30.200776433] [3038] INFO RPI raspberrypi.cpp:1476 Registered camera /base/soc/i2c0mux/i2c@1/imx708@1a to Unicam device /dev/media2 and ISP device /dev/media3
[10:36:30.201647446] [3037] INFO Camera camera.cpp:1028 configuring streams: (0) 2304x1296-YUV420
[10:36:30.201950944] [3038] INFO RPI raspberrypi.cpp:851 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 2304x1296-SBGGR10_1X10 - Selected unicam format: 2304x1296-pBAA
#0 (0.00 fps) exp 29981.00 ag 1.49 dg 1.05
#1 (30.01 fps) exp 29981.00 ag 1.49 dg 1.05
#2 (30.01 fps) exp 29981.00 ag 1.55 dg 1.01
#3 (30.01 fps) exp 29981.00 ag 1.56 dg 1.01
#4 (30.01 fps) exp 29981.00 ag 1.57 dg 1.00
#5 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#6 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#7 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#8 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#9 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#10 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#11 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#12 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#13 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#14 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#15 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#16 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#17 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#18 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#19 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#20 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#21 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#22 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#23 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#24 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#25 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#26 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#27 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#28 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#29 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#30 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#31 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#32 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#33 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#34 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#35 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#36 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#37 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#38 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#39 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#40 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#41 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#42 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#43 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#44 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#45 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#46 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#47 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#48 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#49 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#50 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#51 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#52 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#53 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#54 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#55 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#56 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#57 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#58 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#59 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#60 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#61 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#62 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#63 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#64 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#65 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#66 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#67 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#68 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#69 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#70 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#71 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#72 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#73 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#74 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#75 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#76 (30.01 fps) exp 29981.00 ag 1.60 dg 1.00
#77 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#78 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#79 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#80 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#81 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#82 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#83 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#84 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#85 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#86 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#87 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#88 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#89 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#90 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#91 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#92 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#93 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#94 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#95 (30.01 fps) exp 29981.00 ag 1.60 dg 1.00
#96 (30.01 fps) exp 29981.00 ag 1.60 dg 1.00
#97 (30.01 fps) exp 29981.00 ag 1.61 dg 1.00
#98 (30.01 fps) exp 29981.00 ag 1.62 dg 1.00
#99 (30.01 fps) exp 29981.00 ag 1.63 dg 1.00
#100 (30.01 fps) exp 29981.00 ag 1.64 dg 1.00
#101 (30.01 fps) exp 29981.00 ag 1.64 dg 1.00
#102 (30.01 fps) exp 29981.00 ag 1.63 dg 1.00
#103 (30.01 fps) exp 29981.00 ag 1.62 dg 1.00
#104 (30.01 fps) exp 29981.00 ag 1.61 dg 1.00
#105 (30.01 fps) exp 29981.00 ag 1.61 dg 1.00
#106 (30.01 fps) exp 29981.00 ag 1.63 dg 1.00
#107 (30.01 fps) exp 29981.00 ag 1.62 dg 1.00
#108 (30.01 fps) exp 29981.00 ag 1.62 dg 1.00
#109 (30.01 fps) exp 29981.00 ag 1.61 dg 1.00
#110 (30.01 fps) exp 29981.00 ag 1.60 dg 1.00
#111 (30.01 fps) exp 29981.00 ag 1.60 dg 1.00
#112 (30.01 fps) exp 29981.00 ag 1.60 dg 1.00
#113 (30.01 fps) exp 29981.00 ag 1.60 dg 1.00
#114 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#115 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#116 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#117 (30.00 fps) exp 29981.00 ag 1.59 dg 1.00
#118 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#119 (30.01 fps) exp 29981.00 ag 1.59 dg 1.00
#120 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#121 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#122 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#123 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#124 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#125 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#126 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#127 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#128 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#129 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#130 (30.01 fps) exp 29981.00 ag 1.57 dg 1.00
#131 (30.01 fps) exp 29981.00 ag 1.57 dg 1.00
#132 (30.01 fps) exp 29981.00 ag 1.57 dg 1.00
#133 (30.01 fps) exp 29981.00 ag 1.57 dg 1.00
#134 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#135 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#136 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#137 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#138 (30.01 fps) exp 29981.00 ag 1.58 dg 1.00
#139 (30.01 fps) exp 29981.00 ag 1.57 dg 1.00
#140 (30.01 fps) exp 29981.00 ag 1.57 dg 1.00
#141 (30.01 fps) exp 29981.00 ag 1.57 dg 1.00
#142 (30.01 fps) exp 29981.00 ag 1.57 dg 1.00
However, when I try to access the Camera in OctoPrint I'm told it's inaccessible.
Error Messages displayed using the "TimeLapse+" plugin. I'm showing the first message when I tried using "Localhost" in the URL, then again using IP equivalent.
Error Messages
Could not retrieve Webcam Snapshot: HTTPConnectionPool(host='localhost', port=8080): Max retries exceeded with url: /?action=snapshot (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xef5b59b8>: Failed to establish a new connection: [Errno 111] Connection refused'))
Could not retrieve Webcam Snapshot: HTTPConnectionPool(host='127.0.0.1', port=8080): Max retries exceeded with url: /?action=snapshot (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xef551640>: Failed to establish a new connection: [Errno 111] Connection refused'))
When I use the built-in OctoPrint tools, none of them can connect to the camera.
Snapshot Error Message
Snapshot test failed
Could not retrieve snapshot URL, please double check the URL
Streaming Error Message
Stream test
If you see your webcam stream below, the entered stream URL is ok.! ![]()
Reading through all the release notes about the new release has a lot of information, but I think I'm looking for something specific about how to configure OctoPrint to have access to the camera connected to the RPi. I think there's something about the "Virtual" install that may be at play, but I just can't seem to find that information that would crack this open for me.
Logs
- octoprint-systeminfo-20230526203227.zip (36.1 KB)
- syslog.zip (64.0 KB)
- I can't seem to find the 'webcamd.log' or 'dmesg' on the path suggested. Nor is it showing up in the logs in Octoprint.
OctoPrint: 1.9.0
Raspberry Pi OS Lite: Bullseye
I'm running OctoPrint on a Raspberry Pi OS installation. Long story short, every time I've used the OctoPi image my networking (wireless & wired) stops working after the system has been restarted after having been shut down rendering the RPi completely inaccessible. Networking has been completely reliable so far in this current setup.
