Raspberry Pi Camera Module V2 ( RPI-CAM-V2))
Can't rotate the camera to 180 degrees
tried to use the "Webcam Classic", and "Camera Settings" plugins to rotate a camera. I tried to edit /boot/octopi.txt as well didn't work out.
see the attachment
octoprint-systeminfo-20230704113427.zip (824.4 KB)
OctoPrint 1.9.1 version, OctoPi 1.0.0 version, Ender 3 Neo
Hello,
I'm having a hard time rotating or changing settings for the camera (such as resolution and refresh rate) that I have connected to my Raspberry Pi 4 B.
According to the documentation here, I should be able to edit settings for the camera in boot/octopi.txt however any changes I made it didn't affect the camera after reboot. The same situation with plugins, I have set up the settings and clicked "Save" and rebooted (just to be sure) - no changes. The video output available at http://octopi.local/webcam/?action=stream is still upside down
I more carefully inspected the octopi.txt file and was able to find that raspicam support is available in the "input_uvc module", I have tried to search the location of the module without any success.
Any advice would be appreciated!
