Camera modelraspberry pi camera
I successfully connect to my raspberry pi 4 with octoprint, but then when I go to control tab, it will at first say webcam stream loading, and then give me this message. I know the ribbon cable hooked up correctly because there is a light on the camera that lights up when the raspberry pi is on.
**What did you already try to solve it?**I have went into configuration settings on the raspberry pi and enabled the camera, did "sudo update" and "sudo upgrade" and I still can't get it to work. I have searched the internet to try and solve the problem, but nothing has worked. Thank you for any help that you have to offer.
