Raspberry Pi camera V2 IMX219
Can not get video to show in octoprint. (Webcam stream not loaded)
Running libcamera-hello in Putty does show the camera and no errors
Raspberry pi 5 with Raspberry os. Octorprint installed with Octoprint_Deploy
New to all of this so not much
yes
no
octoprint.log (255.3 KB)
serial.log (148 Bytes)
plugin_softwareupdate_console.log (16.8 KB)
plugin_softwareupdate_update.log (180 Bytes)
tornado.log (129.6 KB)
What streaming tools did you select in octoprint_deploy?
Ustreamer does not work with libcamera, so you can only use usb cameras with this (it used to work in the pre-libcamera age). You might still be able to enable the legacy stack, but I don't know how well this works on a Pi 5 which likely demands the newer software
Camera-streamer should support libcamera, but you have to build it without the hardware acceleration, since RPi 5 got rid of this.
I started over and selected Camera-streamer instead. still getting the same Webcam stream not loaded fault. I also changed the camera settings in /etc/systemd/system/cam_Ender3.service. and by settings i mean resolution and fps.
If i press the configured stream URL link, fault code 503 Service Unavailable appears in the new chrome page.
