Raspberry Pi Internet Connection Troubles
Hello! I am trying to install the OctoPi/Klipper combo available in the Raspberry Pi Imager. I don't want to install Klipper separately because I don't want to mess around with SSH-ing. I have a Raspberry Pi 4B, my computer is Windows 10. My Pi isn't showing on the router, and I can't access it under raspberrypi.local. The little green light on the Pi blinks 8 times when powered up. If someone would please help me fix this, that would be great! I also would prefer not to download any software to fix it, if possible. Thank you for your time and I look forward to your response!
  • Made sure the internet settings were right
  • Changed the Host Name to raspberrypi
  • Tried different SD Cards
  • Tried searching IP Addresses that were labeled "Unknown Device" (Question: Will a Raspberry Pi always be labeled "Raspberry" something in the router and will the single digit number always be a '0'?)
N/A
N/A
N/A
Note: I have run OctoPrint on this Pi but I deleted it to upgrade to Klipper. After I set up OctoPrint for the first time I did have trouble logging in via "octopi.local". I got a "This Site Can't Be Reached" message. It took a few tries, but I did end up getting it to work by re-opening the tab repeatedly.
Are you sure it's not 7 times?
7 times means something is wrong with the image on the sdcard and it can't boot
8 times means SDRAM failure
Don't count the long flashes - only the short flashes are the error code
You also can try by connecting a HDMI TV/monitor to the Pi to see what going on during boot.
Thanks for the heads up on the flashes! The short flashes blink 3 times.
Whoops! Now they're flashing 4 times!
And on the screen?
I still can't reach my Pi. What screen? (Sorry, this is my first Raspberry Pi experience!)
That one. I thought you did.
Oh, sorry! I will try that and let you know!
Hello again! I found out that do not have a HDMI cord the right size to connect to anything. Is there any other things I could try? Thanks!
Buying a proper HDMI cable would be a good investment. For an RPi 4B, use https://www.amazon.com/gp/product/B06WWQ7KLV.
Alternatively, in addition to the cable, you could purchase either https://www.amazon.com/gp/product/B07VNX4ZWY or https://www.amazon.com/dp/B087RC8B79.
I also have a mini-keyboard, https://www.amazon.com/gp/product/B01IQL2VCE
I have found the small monitor and the mini-keyboard very useful for troubleshooting a variety of SBC projects.
Thanks! I will consider that.
Hello Again! I bought an HDMI cord as suggested by b-morgan, but I can't access it. Could someone help me with connecting it?
