I am setting up my laser engraver with a raspberry pi cnc hat version 2.6 by Protoneer. it controls the laser. how do I install octoprint so it connects , because the raspberry pi is the controller? thanks
That's interesting.
If you had a two-board system, I would naively guess that one of the Grbl support plugins might be of use. But then again, you've got everything on the same board.
You might just try Protoneer's IMG and investigate the bCNC software they've provided to see what's going on.
