Hello everyone, i like very much octoprint ad i'm tryng to intstall it on an old raspberry pi b 2. It Works !
The hardware isnt'n good for octoprint, but i have to make very simple things.
I'm tryng to install a wifi usb dongle, i've tryed two different models but without success.
Can anybody help me ? Thanks To all !
i tried to install more drivers but no compatity for 5.10.103+ kernel
pi@octopi:~ $ lsusb
Bus 001 Device 004: ID 0bda:b812 Realtek Semiconductor Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub
pi@octopi:~ $
pi@octopi:~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.5 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::2164:f251:9ddf:3dc7 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:53:be:88 txqueuelen 1000 (Ethernet)
RX packets 22155 bytes 5746914 (5.4 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 3025 bytes 523423 (511.1 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 848 bytes 130573 (127.5 KiB)
TX packets 848 bytes 130573 (127.5 KiB)
pi@octopi:~ $ sudo sh -c 'wget deb.trendtechcn.com/install -O /tmp/install && sh /tmp/install'
[sudo] password for pi:
URL transformed to HTTPS due to an HSTS policy
--2022-05-07 17:40:59-- https://deb.trendtechcn.com/install
Resolving deb.trendtechcn.com (deb.trendtechcn.com)... 185.199.108.153, 185.199.109.153, 185.199.110.153, ...
Connecting to deb.trendtechcn.com (deb.trendtechcn.com)|185.199.108.153|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 16748 (16K) [application/octet-stream]
Saving to: ‘/tmp/install’
/tmp/install 100%[===================>] 16.36K --.-KB/s in 0.02s
2022-05-07 17:40:59 (947 KB/s) - ‘/tmp/install’ saved [16748/16748]
Package manager is: apt-get
Installing prerequisites
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 https://deb.trendtechcn.com stable InRelease
Reading package lists... Done
Downloading the driver
2022-05-07 17:42:00 URL:https://deb.trendtechcn.com/rtl88x2bu-dkms.deb [4121384/4121384] -> "rtl88x2bu-dkms.deb" [1]
Installing and compiling the driver
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
Aborting, command failed: apt install --yes --no-install-recommends ./rtl88x2bu-dkms.deb
ERROR: The driver was NOT successfully installed!
1) Please select all the text in this terminal, then right click with the
mouse and select Copy, and finally paste all the text in an email to:
support@trend-tech.net.cn
2) Please attach this autogenerated log file to the email:
/tmp/troubleshooting.txt
3) Some common problems are documented in:
https://deb.trendtechcn.com/troubleshooting/
then......
pi@octopi:~ $ sudo dpkg --configure -a
Setting up rtl88x2bu-dkms (5.13.1-20b2) ...
Removing old rtl88x2bu-5.13.1 DKMS files...
Deleting module version: 5.13.1
completely from the DKMS tree.
Done.
Loading new rtl88x2bu-5.13.1 DKMS files...
It is likely that 5.10.103+ belongs to a chroot's host
Building for 5.10.103+, 5.10.103-v7+, 5.10.103-v7l+, 5.10.103-v8+, 5.15.36+, 5.15.36-v7+, 5.15.36-v7l+ and 5.15.36-v8+
Module build for kernel 5.10.103+ was skipped since the
kernel headers for this kernel does not seem to be installed.
Building initial module for 5.10.103-v7+
... and it stops a long of time... hours
I think here down is the problem, how can i do ?
i'm not very expert in linux, I never did compiled anything.
*Loading new rtl88x2bu-5.13.1 DKMS files...*
*It is likely that 5.10.103+ belongs to a chroot's host*
*Building for 5.10.103+, 5.10.103-v7+, 5.10.103-v7l+, 5.10.103-v8+, 5.15.36+, 5.15.36-v7+, 5.15.36-v7l+ and 5.15.36-v8+*
*Module build for kernel 5.10.103+ was skipped since the*
*kernel headers for this kernel does not seem to be installed.*
