I have the following considerations and would like to implement them with ssh from the shell and also not with a plugin for the WEB frontend.
If I am directly on my Octoprint Pi with (ssh connection) I would like to transfer a GCODE control command to the running system while it is printing.
I would like to achieve the same thing as via the web frontend only as an entry with ssh.
In which file do I have to write my control command so that it is recorded in the current G-CODE that is currently being printed?
Or does anyone have a simpler solution from the shell?
Greetings Raini
