I'm trying to confirm if the Zero 2 has less WiFi 'capability' than the old Zero W as I'm struggling with intermittent disconnection issues that I believe is related to RF interference.
Problem:
Recently switched from a Raspberry Pi Zero W to a Zero 2 as an OctoPrint host on my Prusa i3 MK3S+ (connected via GPIO pins). While the Zero wasn't supported; it mostly worked for monitoring without any real issue and the wireless connection was rock-solid. (No connection problems in more than a year.) I upgraded to the Zero 2 when it came out so that I felt comfortable running some plugins, etc, rather than just using it for monitoring.
Attempts to Solve
I have already turned off power management on the Zero 2 (which apparently is enabled by default) and caused me some early issues. While my printer (with the Zero 2) was in my kitchen (with good connectivity to the AP), the connection was up for several days. When I moved it back into the enclosure in the garage, I am able to connect during work-days in the morning, but by noon. I had a ping running for a while (checking every 60s) and it seems like OctoPrint was connected sporadically, leading me to believe wireless interference is the problem. However, again, for over a year I didn't have the same problems with a Zero W.
Can anyone confirm this is a problem or give me some other suggestions for fixing this (other than the obvious: move the printer, add an AP to my garage, or use a different RPi via ethernet). If there is any other info that might be useful, please let me know. Thanks very much.
I can only report that I have a similar if not identical problem. I have the same printer, raspberry and octoprint. I had no issue for 6 months. I moved the printer further away in the house tonight. Everything was fine for few hours, then suddenly it disconnected while I was uploading a file to octoprint. I had a print going at the same time. The raspberry pi zero 2 has not connected back so far. The print is still going. I suppose the rasbberry pi is still running, but not reconnecting actively. Or maybe when the signal is weaker it uses more power for the antenna and maybe overheat or something like that?
I am still having this problem with no resolution. However, to add to the information, I watched dmesg until it "fell off" the network today, and received the following messages (the first line suddenly repeated hundreds of times and then the connection froze after the second message).
My searches indicate a similar problem happened to RPi4Bs but was apparently resolved with a patch over a year ago. I would welcome any suggestion for information I should gather or how I can further troubleshoot this problem?
Yesterday I did a clean install of Ubuntu 22.04.1 server (and installed octoprint manually via pip). The Zero 2 W is having the same issue. As a result, I suspect it isn't a octoprint problem but a RPi Zero 2 W problem. I'm not sure where to go from here to seek a solution.
