Raspi Cam v3
Im using the new camera stack. After I pulged in an USB Cam, just to test, the Raspi Com stream stoppt working, and is still not working anymore after unplugging usb cam.
Remove usb-cam Config
Camera ist listet in
libcamera-hello --list-cameras
Available cameras
0 : imx708 [4608x2592] (/base/soc/i2c0mux/i2c@1/imx708@1a)
Modes: 'SRGGB10_CSI2P' : 1536x864 [30.00 fps - (0, 0)/0x0 crop]
2304x1296 [30.00 fps - (0, 0)/0x0 crop]
4608x2592 [30.00 fps - (0, 0)/0x0 crop]
but
libcamera-hello throws an error:
libcamera-hello
Preview window unavailable
[0:05:42.347940020] [1446] INFO Camera camera_manager.cpp:297 libcamera v0.0.5+83-bde9b04f
[0:05:42.409347955] [1447] INFO RPI vc4.cpp:437 Registered camera /base/soc/i2c0mux/i2c@1/imx708@1a to Unicam device /dev/media4 and ISP device /dev/media0
[0:05:42.409416140] [1447] INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[0:05:42.409709505] [1446] INFO Camera camera.cpp:840 Pipeline handler in use by another process
ERROR: *** failed to acquire camera /base/soc/i2c0mux/i2c@1/imx708@1a ***
YES
NO
in camera-stack.jornal are erros too:
c 24 13:51:43 octoprint sh[664]: [0:00:12.906228158] [689] WARN IPARPI ipa_base.cpp:1070 Could not set AF_TRIGGER - no AF algorithm or not Auto
Dec 24 13:51:43 octoprint sh[664]: device/buffer_list.c: CAMERA:capture: Streaming started... Was 0 of 2 enqueud
Dec 24 13:51:43 octoprint sh[664]: device/buffer_list.c: SNAPSHOT:output:mplane: Streaming started... Was 0 of 2 enqueud
Dec 24 13:51:43 octoprint sh[664]: device/buffer_list.c: RESCALLER:STREAM:output:mplane: Streaming started... Was 0 of 2 enqueud
Dec 24 13:51:43 octoprint sh[664]: device/buffer_list.c: SNAPSHOT:capture:mplane: Streaming started... Was 0 of 2 enqueud
Dec 24 13:51:43 octoprint sh[664]: device/buffer_list.c: RESCALLER:STREAM:capture:mplane: Streaming started... Was 0 of 2 enqueud
Dec 24 13:51:43 octoprint sh[664]: device/buffer_list.c: STREAM:output:mplane: Streaming started... Was 0 of 2 enqueud
Dec 24 13:51:43 octoprint sh[664]: device/buffer_list.c: VIDEO:output:mplane: Streaming started... Was 0 of 2 enqueud
Dec 24 13:51:43 octoprint sh[664]: device/buffer_list.c: STREAM:capture:mplane: Streaming started... Was 0 of 2 enqueud
Dec 24 13:51:43 octoprint sh[664]: device/buffer_list.c: VIDEO:capture:mplane: Streaming started... Was 0 of 2 enqueud
Dec 24 13:51:44 octoprint sh[664]: [0:00:14.068662324] [686] WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[24:cap]: Dequeue timer of 1000000.00us has expired!
Dec 24 13:51:44 octoprint sh[664]: [0:00:14.068766361] [686] ERROR RPI pipeline_base.cpp:1333 Camera frontend has timed out!
Dec 24 13:51:44 octoprint sh[664]: [0:00:14.068804195] [686] ERROR RPI pipeline_base.cpp:1334 Please check that your camera sensor connector is attached securely.
Dec 24 13:51:44 octoprint sh[664]: [0:00:14.068841991] [686] ERROR RPI pipeline_base.cpp:1335 Alternatively, try another cable and/or sensor.
Dec 24 13:52:59 octoprint sh[664]: util/http/http.c: HTTP8080/0: Client connected 127.0.0.1 (fd=4).
Dec 24 13:52:59 octoprint sh[664]: util/http/http.c: HTTP8080/0: Request 'GET' '/' 'action=stream&nonce_dashboard=1703422375989'
Dec 24 13:52:59 octoprint sh[664]: util/http/http.c: HTTP8080/1: Client connected 127.0.0.1 (fd=5).
Dec 24 13:52:59 octoprint sh[664]: util/http/http.c: HTTP8080/1: Request 'GET' '/' 'action=stream'
Dec 24 13:52:59 octoprint sh[664]: [0:01:09.810281773] [686] ERROR Camera camera.cpp:1135 Request(0:X:0/1:0) is not valid
Dec 24 13:52:59 octoprint sh[664]: [0:01:09.810361347] [686] ERROR Camera camera.cpp:1135 Request(1:X:0/1:1) is not valid
Dec 24 13:53:01 octoprint sh[664]: util/http/http.c: HTTP8080/0: Client disconnected 127.0.0.1.
Dec 24 13:53:01 octoprint sh[664]: util/http/http.c: HTTP8080/1: Client disconnected 127.0.0.1.
Dec 24 13:53:07 octoprint sh[664]: util/http/http.c: HTTP8080/2: Client connected 127.0.0.1 (fd=6).
Dec 24 13:53:07 octoprint sh[664]: util/http/http.c: HTTP8080/2: Request 'GET' '/' 'action=stream'
Dec 24 13:53:09 octoprint sh[664]: util/http/http.c: HTTP8080/2: Client disconnected 127.0.0.1.
- OctoPrint 1.9.3
- Python 3.9.2
- OctoPi* 1.0.0cam (build 2023.10.09.154319)
