Raspberry Pi Camera 1.3
I followed the Octolapse guide to enable manual settings for the camera. The guide recommends (and octolapse requires) to set up the camera as USB in octopi.txt, with enabling the kernel module for the camera driver. I get a stream and i can set all the settings, but the stream has heavy compression artifacts, which it does not have when i modify octopi.txt to access the camera as raspi. However, if i do that, i do not have the manual settings enabled. Please see the attached screenshot for an example of the artifacts.
- Change the resolution in octopi.txt
- Search for information and guides
webcamd.log
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: usb
usb options: -r 1920x1080 -f 30
raspi options: -fps 25 -x 1920 -y 1080
http options: -w ./www
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
raspi
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Mar 12 09:32:26 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www -i input_uvc.so -r 1920x1080 -f 30 -d /dev/video0
i: Desired Resolution: 1920 x 1080
i: Frames Per Second.: 30
i: Format............: JPEG
o: www-folder-path......: ./www/
o: HTTP Listen Address..: (null)
o: commands.............: enabled
Goodbye...
Octoprint 1.5.3, Octopi 0.18.0
