Raspi camera stopped working after update
Raspi camera v2 and v1.3
I can't get Octoprint to display anything from the camera. I tried both cameras, only got 1 small LED flash from the camera when booting with the 1.3 and then nothing.
I tried checking the cables, reseating them, used 2 different camera modules, changing /boot/config.txt and octopi.txt settings. None of it worked. I can still print but I cannot get the camera to work.
Yes
octoprint-systeminfo-20230816153942.zip (1.3 MB)
vcgencmd get_camera returns supported=1 and detected=1
Raspberry Pi 3b+ running Octoprint 1.9.2 and Octopi 0.18.0. Connected via microusb to the printer.
You said 'after update'. What update did you do?
I believe the update to 1.9.2 and Octopi 0.18.0 were the updates I applied.
I have a working RPi Camera 2 on a RPi 3B using OctoPi 0.18.0 and OctoPrint 1.9.2. My printer is a LulzBot TAZ 6.
vcgencmd get_camera returns supported=1 detected=1 and I haven't messed with /boot/config.txt or /boot/octopi.txt. I have attached my files for your convenience.
Temp.zip (2.5 KB)
With those /boot files, here is the webcamd.log:
webcamd.log.1.zip (1022 Bytes)
Hopefully, this information from a working system very similar to yours (I have 3B, you have 3B+ and our printers are probably different) will help you get your camera working.
I figured out my issue. I tried 2 different raspberry pis, both 3b+, and discovered my pi camera would not turn on regardless of what power supply, ribbon cable, or versions of the 0.18.0 Octopi I used. I downloaded the latest version of Octopi from the github page (1.0.0) and flashed a new SD Card; guess what, it worked! Camera light would turn on and things seemed to be working. I will update if there is any problems with the recovery process, but I'm hopeful this will be a smooth transition.
