What is the problem? webcamd daemon service not launching
What did you already try to solve it? i did a restore of the webcamd daemon on my local disk trough wincsp
octoprint log
2021-02-15 09:19:59,625 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-15 09:19:59,692 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2021-02-15 09:19:59,694 - octoprint.server - INFO - OctoPrint 1.5.3
2021-02-15 09:19:59,710 - octoprint.plugin.core - INFO - 24 plugin(s) registered with the system:
| Access Anywhere - The Spaghetti Detective (1.5.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_thespaghettidetective
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| Bed Visualizer (1.0.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| File Check (2020.8.7) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
| Firmware Check (2021.2.4) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| MultiCam (0.2.8) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_multicam
| Octolapse (0.4.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse
| Printoid Plugin (1.0.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_printoid
| *Prusa Mini ETA Plugin (0.1.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_prusa_mini_eta
| Themeify (1.2.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_themeify
2021-02-15 09:19:59,724 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 915058688
| os:
| bits: 32
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.17.0
| throttle_state: '0x0'
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
webcamd log
-- Logs begin at Mon 2021-02-15 20:06:01 CET, end at Mon 2021-02-15 20:17:01 CET. --
Feb 15 20:06:05 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Feb 15 20:06:05 octopi systemd[305]: webcamd.service: Failed to execute command: Permission denied
Feb 15 20:06:05 octopi systemd[305]: webcamd.service: Failed at step EXEC spawning /root/bin/webcamd: Permission denied
Feb 15 20:06:05 octopi systemd[1]: webcamd.service: Control process exited, code=exited, status=203/EXEC
Feb 15 20:06:05 octopi systemd[1]: webcamd.service: Failed with result 'exit-code'.
Feb 15 20:06:05 octopi systemd[1]: Failed to start the OctoPi webcam daemon with the user specified config.
Feb 15 20:06:05 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling restart.
Feb 15 20:06:05 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 1.
Feb 15 20:06:05 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Feb 15 20:06:05 octopi systemd[394]: webcamd.service: Failed to execute command: Permission denied
Feb 15 20:06:05 octopi systemd[394]: webcamd.service: Failed at step EXEC spawning /root/bin/webcamd: Permission denied
pi@octopi:/boot $ nano octopi.txt
GNU nano 3.2 octopi.txt
# Using the following option it is possible to add additional devices. If
# your webcam happens to show above symptoms, try determining your cam's
# vendor and product id via lsusb, activating the line below by removing # and
# adding it, e.g. for two broken cameras "aabb:ccdd" and "aabb:eeff"
# additional_brokenfps_usb_devices=("aabb:ccdd" "aabb:eeff")
# If this fixes your problem, please report it back so we can include the device
# out of the box: https://github.com/guysoft/OctoPi/issues
#additional_brokenfps_usb_devices=()
### Additional options to supply to MJPG Streamer for the RasPi Cam
# See https://faq.octoprint.org/mjpg-streamer-config for available options
# Defaults to 10fps
camera_raspi_options="-x 2592 -y 1944 -fps 20"
### Configuration of camera HTTP output
# Usually you should NOT need to change this at all! Only touch if you
# know what you are doing and what the parameters mean.
# Below settings are used in the mjpg-streamer call like this:
# -o "output_http.so -w $camera_http_webroot $camera_http_options"
# Current working directory is the mjpg-streamer base directory.
camera_http_webroot="./www"
camera_http_options=""
raspberry 3b+
OctoPrint version : 1.5.3
OctoPi version : 0.17.0
i'll made a quick video to show that the camera is working
check @ 00.12 https://youtu.be/lSuvfn2eCEo
