RaspiCam V3 - RPi5 - Not working New Camera Stack
RaspiCam Module 3
Installed the Camera Stack OctoPi but i cant seem to get the RPi 5 to detect the Module 3 cam. I have logged onto terminal and ran the necessary Sudo:
sudo apt update
sudo apt install libcamera-apps
Have also used Rpicam-hello (It works with the Rpi OS and once on the octopi)
When i update with sudo update - the whole system crashes and will not reboot.
I just cant seem to make it work - and any advice would help.
Installed, reformatted, reinstalled - multiple times
Installed Rpi OS and it detects the cam
intalled octopi - camerastack multiple times - once it detected the camera then it dissapeared after
Yes
octoprint-systeminfo-20260114101344.zip (88.9 KB)
Latest OctoPrint Camera Stack - with RPi Imager Ver 2.0
Rpi 5
RaspiCam Module V3
Bought a USB cam - Logitech Brio 100 - as common as possible - and its also not working.
https://paste.octoprint.org/CteZ5nXGiU
Need some support to see what i am doing wrong? Should i update the whole thing again? Do i use the normal Octo Print with the USB Cam?
I did a back up - when i recreate a new Octopi - will the backup overwrite>? or only the plugins used?
i have updated the OS - to the 1.11.5 via the system updates - still doesnt work.
Im lost... ill take any help i can get... preference would be to use the Module 3 - but if i cant then the Logitech
octoprint-systeminfo-20260114161048.zip (153.1 KB)
Managed to move ahead somewhat:
refreshed with RPI OS lite
Used this guide to MANUALLY install - GitHub - paukstelis/octoprint_deploy: Bash script for rapid deployment of multiple octoprint instance on a single machine
RPICAM - still does not work
USB Cam - Works
  • can take pic
  • can see stream on OctoEverywhere dashboard on web browser but not on phone app
  • CANNOT see stream on OCTOPI - for the life of me not able to figure this one out - if anyone can give guidance - would be spectacular
Unfortunately, the Raspberry Pi 5 is missing a video hardware encoder that exists in previous versions. This missing encoder has caused many of the "camera solutions" to fail including the ones included with both OctoPi images.
https://community.octoprint.org/t/pi5-raspberry-pi-module-3/62453
https://github.com/ayufan/camera-streamer/issues/149
https://github.com/OctoPrint/OctoPi-UpToDate/issues/19
There are additional threads in this forum that discuss the RPi 5 (or RPi5) as a suitable host for OctoPrint with the general concensus that it is overkill. At this point in time, an RPi 4 is a much better choice.
If i were to use a RPi4 as the base - i can run the webcams without issues? USB and if i chose to the Module 3?
This exercise has cost me much... hahaha
Yes, the RPi Camera V3 works on the OctoPi 1.1.0 cam release on an RPi 4 (I have this config). I believe USB cameras will work as well (don't have any USB cameras ATM).
i took the leap and got RPi4.
Question - when i install the Camera stack now - do i upgrade it to 1.11.5 or keep it at 1.11.4 after installing it requests for upgrade
i can 100% confirm - the camera stack upgraded to 1.11.5 - works
Rpi4 2GB - works like a charm - will detect both USB cam AND RaspiCam Module3 without any updates.
confirmed RPi5 - doesnt work
I gave up on the RaspcCams (tried all sorts) , on my RB5, but a cheap USB cam is working.
Man - the Rpi5 couldnt even detect my cheap USB cam - ust agve up on it made it in to a Home Assistant and got a Pi4
