Hello,
I moved my printer to a dark cabinet and decided I needed a webcam to watch progress. I naively bought a Razer Kiyo as it had a built in light. It's plugged into my Pi, and cam is working, but of course I have no way to control the light. The Razer site says:
"The s ring light is automatically enabled when you launch a compatible camera or third party broadcasting software with the Razer Kiyo set as its capture device. You may then rotate the Ring light adjustment knob clockwise or counterclockwise to increase or decrease the brightness of the ring light as needed."
I need to find a way for the print to trigger the light coming on and off ideally. I am a programmer so I could probably try to modify a plugin to do this somehow, but if there is something existing that'll do this, or a plugin I could contribute to that'd make much more sense.
Has anyone any ideas how to get this working please? Or a recommendation for an active webcam plugin I could extend possibly. Hopefully you can send a command to the webcam for light on/off.
Cheers
Russ
