I get this erro after i manually deleted a old octoprint install ( 1 year old ) and install the latest from git.
File "/usr/local/bin/octoprint", line 5, in
from pkg_resources import load_entry_point
File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2876, in
working_set = WorkingSet._build_master()
File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 451, in _build_master
return cls._build_from_requirements(requires)
File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 464, in _build_from_requirements
dists = ws.resolve(reqs, Environment())
File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 644, in resolve
raise VersionConflict(dist, req)
pkg_resources.VersionConflict: (certifi 2016.09.26 (/usr/local/lib/python2.7/dist-packages/certifi-2016.09.26-py2.7.egg), Requirement.parse('certifi>=2017.4.17'))
What did you already try to solve it?`
I tried installing 3 times and got the same eroor
Logs (octoprint.log, serial.log or output on terminal tab, ...)
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, ...)
Corexy with repetier firmware dev branch
