I'm building a custom large format printer (1200x400mm) and I'm trying to figure out a way to get some heatbeds working for my setup. I've ordered 3x 350x350mm beds and I want to be able to turn them on/set temperature either for all 3 or just individual beds.
I'm using an Analog Digital Converter and voltage divider circuit to read thermistor voltage and a python script to convert that to temperature using the Steinhart-Hart Equation.
But I'm stuck in how to incorporate this into Octoprint (I'm fairly new to python).
I'm not sure if something like the Enclosure plugin could be used/modified to do what I want. Eventually I'll need to use this temperature data to trigger a SSR for each bed as the bed temps change. Also I realise I won't have any of the safety features, overtemp etc, that Marlin provides. But I think modifying Marlin to work with my setup is going to be more tricky.
This is the script I'm currently testing out to ready 2 spare small heatbeds I've got lying around while I wait for the new ones to arrive. As I said I'm new to python so I'm basically just copy and pasting at this stage.
import time
import board
import busio
import adafruit_ads1x15.ads1115 as ADS
from adafruit_ads1x15.analog_in import AnalogIn
# Create the I2C bus
i2c = busio.I2C(board.SCL, board.SDA)
# Create the ADC object using the I2C bus
ads = ADS.ADS1115(i2c)
# Create single-ended input channels
chan0 = AnalogIn(ads, ADS.P0)
chan1 = AnalogIn(ads, ADS.P1)
R0 = 100000 * ((3.3 / chan0.voltage ) -1)
R1 = 100000 * ((3.3 / chan1.voltage ) -1)
def steinhart_temperature_C_0(r, Ro=100000.0, To=25.0, beta=4147.29):
import math
steinhart = math.log(r / Ro) / beta # log(R/Ro) / beta
steinhart += 1.0 / (To + 273.15) # log(R/Ro) / beta + 1/To
steinhart = (1.0 / steinhart) - 273.15 # Invert, convert to C
return steinhart
def steinhart_temperature_C_1(r, Ro=100000.0, To=25.0, beta=4147.29):
import math
return steinhart
#R0 = 100000 * ((3.3 / chan0.voltage ) -1)
#R1 = 100000 * ((3.3 / chan1.voltage ) -1)
print("{:>5}".format("A0 Temp:") , "{:>5.3f}".format(steinhart_temperature_C_0(R0)) ," |" , "{:>5}$
OctoPi version: 1.4.0
Cusom Printer: Marlin 2.0.5
