I had to reboot the Raspberry and the OctoPrint is dead.
I upgraded the system, upgraded PIP, upgraded OctoPrint and still the same.
service octoprint restart - does nothing
manually starts octoprint gives:
Starting the server via "octoprint" is deprecated, please use "octoprint serve" from now on.
2019-08-25 19:36:33,933 - octoprint.startup - INFO - ******************************************************************************
2019-08-25 19:36:33,935 - octoprint.startup - INFO - Starting OctoPrint 1.3.11
2019-08-25 19:36:33,937 - octoprint.startup - INFO - ******************************************************************************
2019-08-25 19:36:34,020 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2019-08-25 19:36:34,022 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-08-25 19:36:34,196 - octoprint.plugin.core - ERROR - Error loading plugin softwareupdate
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 863, in _import_plugin
instance = imp.load_module(module_name, f, filename, description)
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 12, in <module>
import flask
EOFError: EOF read where object expected
2019-08-25 19:36:34,210 - octoprint.plugin.core - ERROR - Error loading plugin errortracking
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/errortracking/__init__.py", line 12, in <module>
from flask import jsonify
ImportError: cannot import name jsonify
2019-08-25 19:36:34,355 - octoprint.plugin.core - ERROR - Error loading plugin action_command_prompt
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt/__init__.py", line 9, in <module>
from octoprint.server import user_permission
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/__init__.py", line 10, in <module>
from flask import Flask, g, request, session, Blueprint, Request, Response, current_app
ImportError: cannot import name Flask
2019-08-25 19:36:34,373 - octoprint.plugin.core - ERROR - Error loading plugin logging
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/logging/__init__.py", line 10, in <module>
from octoprint.server import NO_CONTENT, admin_permission
2019-08-25 19:36:34,404 - octoprint.plugin.core - ERROR - Error loading plugin tracking
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/tracking/__init__.py", line 9, in <module>
from flask_babel import gettext
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask_babel/__init__.py", line 16, in <module>
from flask import current_app, request
ImportError: cannot import name current_app
2019-08-25 19:36:34,474 - octoprint.plugin.core - ERROR - Error loading plugin pluginmanager
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager/__init__.py", line 14, in <module>
from octoprint.server.util.flask import restricted_access, with_revalidation_checking, check_etag
2019-08-25 19:36:34,665 - octoprint.plugin.core - ERROR - Error loading plugin announcements
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements/__init__.py", line 23, in <module>
from octoprint.server import admin_permission
2019-08-25 19:36:34,686 - octoprint.plugin.core - ERROR - Error loading plugin forcelogin
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/forcelogin/__init__.py", line 10, in <module>
import flask_login
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask_login.py", line 20, in <module>
from flask import (_request_ctx_stack, abort, current_app, flash, redirect,
ImportError: cannot import name _request_ctx_stack
2019-08-25 19:36:34,750 - octoprint.plugin.core - ERROR - Error loading plugin backup
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/backup/__init__.py", line 11, in <module>
from octoprint.server import admin_permission, NO_CONTENT
2019-08-25 19:36:34,776 - octoprint.plugin.core - ERROR - Error loading plugin appkeys
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/appkeys/__init__.py", line 12, in <module>
2019-08-25 19:36:34,786 - octoprint.plugin.core - ERROR - Error loading plugin corewizard
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/corewizard/__init__.py", line 9, in <module>
2019-08-25 19:36:34,805 - octoprint.plugin.core - ERROR - Error loading plugin pi_support
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pi_support/__init__.py", line 11, in <module>
2019-08-25 19:36:34,820 - octoprint.plugin.core - ERROR - Error loading plugin printer_safety_check
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check/__init__.py", line 10, in <module>
2019-08-25 19:36:34,849 - octoprint.plugin.core - INFO - Plugin Discovery is disabled.
2019-08-25 19:36:36,173 - octoprint.plugin.core - INFO - Plugin ProgressBasedOntime Plugin (0.1.2) is disabled.
2019-08-25 19:36:36,501 - octoprint.plugin.core - ERROR - Error loading plugin PrintTimeGenius
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrintTimeGenius/__init__.py", line 10, in <module>
2019-08-25 19:36:36,561 - octoprint.plugin.core - ERROR - Error loading plugin filamentmanager
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filamentmanager/__init__.py", line 16, in <module>
from .api import FilamentManagerApi
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filamentmanager/api/__init__.py", line 13, in <module>
from flask import jsonify, request, make_response, Response
2019-08-25 19:36:36,749 - octoprint.plugin.core - INFO - Plugin Octolapse (0.3.4) is disabled.
2019-08-25 19:36:37,027 - octoprint.plugin.core - INFO - Found 6 plugin(s) providing 3 mixin implementations, 3 hook handlers
2019-08-25 19:36:37,249 - octoprint.cli.server - ERROR - Uncaught exception
File "./octoprint", line 11, in <module>
load_entry_point('OctoPrint==1.3.11', 'console_scripts', 'octoprint')()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/__init__.py", line 609, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 764, in __call__
return self.main(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 717, in main
rv = self.invoke(ctx)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 1114, in invoke
return Command.invoke(self, ctx)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 956, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 555, in invoke
return callback(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/decorators.py", line 17, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/__init__.py", line 175, in octo
ctx.invoke(serve_command, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/server.py", line 206, in serve_command
ignore_blacklist)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/server.py", line 105, in run_server
from octoprint.server import Server
any help?
