I haven't printer anything for a while and I recently came back to my printer and Octoprint.
And now, every time I start a print, I get a "Recv: echo:busy: paused for user" message on the console.
I have never seen that before, and I don't know how to solve that issue.
I tried to print directly from the printer screen (from an USB key), without Octoprint and it works like a charm.
I also tried safe mode (see below).
Yes.
Not really. I don't get the "Recv: echo:busy: paused for user" message anymore, but the print still never starts.
Done.
Octoprint 1.9.3, everything is up to date.
Custom printer using a Bigtreetech SKR V1.4 Turbo board.
IMPORTANT: it has been working perfectly with Octoprint for months.
Hello,
Sorry for the late answer and thank you for your help.
Here are my answers:
>> The issue you mention (Recv: echo:busy: paused for user) does not appear in the [logs]
But it does on the Octoprint console. Please find a screen copy attached.
Usually you have to hit a button on the printer. OctoPrint just reports that you have to do so.
I tried to push the printer button, but it doesn't help.
And I don't have any message on the printer screen.
>> Can you share the slicer's start gcode and if you have, the start gcode in OctoPrint.
Here it is ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {infill_sparse_density}
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
M205 X8 ;X/Y Jerk settings
G1 Z15.0 F{speed_travel} ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E7 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{speed_travel}
;Put printing message on LCD screen
M117 Rigibot Printing...
>> These commands are not recognized by the firmware. >> M569 is RepRap only.
I don't know where this command comes from. It doesn't seem to be in the slicer's start code.
>> And please turn off the debug logging.
How do I do that? Is this an Octoprint setting? I couldn't find it.
