Let me start by saying that I absolutely love OctoPrint. It makes using my printer so much easier. But I think Octoprint doesn't cares for me in the same way.
I'm not in a position to use my 3D printer on a regular basis. As a result Octoprint sits idle for fairly long periods of time. There no particular pattern to the idleness. Sometimes I go one week between uses, other times I might go three months between uses.
During those idle periods, Octoprint often encounters some kind of problem and shutdown/crashes. Since I'm not using Octoprint during those periods I don't know it has happened and therefore I don't usually know why. I would estimate that in the past 4 years, this has happened 12-15 times. I have never been able to repair the issue (whatever it may have been) and I invariably reinstall Octoprint. That's not so terrible, but taking an hour to re-set-up octoprint every time I want to use it is a hassle.
I guess what I would like to know is this: Is there there a way to prepare Octoprint for extended periods of idleness?
Making Debian read-only (didn't help).
Studying the error logs for some clear failure (nothing has ever stuck out).
Shutting down between Octoprint uses. About half the time Octoprint fails to start-up when I restart the pi.
I have replaced the SD card repeatedly. I'm certain that the SD Card is not becoming corrupted.
Yes.
I doubt this will help. I was typing this cry for help while reimaging Octoprint again.
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:120.0) Gecko/20100101 Firefox/120.0
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1500.0
env.hardware.ram: 912539648
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.1
env.plugins.pi_support.octopi_version: 1.0.0
env.plugins.pi_support.octopiuptodate_build: 1.0.0-1.9.3-20231009151442
env.plugins.pi_support.octopiuptodate_build_short: 2023.10.09.151442
env.python.pip: 22.3
env.python.version: 3.9.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: unknown
octoprint.last_safe_mode.reason: unknown
octoprint.safe_mode: False
octoprint.version: 1.9.3
printer.firmware: Marlin 2.0.9.1 (Sep 25 2021 07:51:49)
systeminfo.generated: 2023-12-17T15:51:09Z
systeminfo.generator: zipapi
