Remote-Control-GCODE Command to repeat Filament feed?
After a lot of time, effort and expense, I have managed to get the MMU3 running almost flawlessly on my MK3S+.
The only, tiny, fly in the ointment is that the filament is very rarely (about every 200-300 tool changes) not sufficiently recognised by the extruder sensor (called ‘FSensor’).
This is not at all tragic, because a single (or at most 2) further attempts then lead to success.
However, my problem is that I often print remotely, i.e. from work and business trips, and cannot make this one further attempt by personally clicking on the printers control panel.
Now, does anyone know if there is a way to confirm/repeat the filament feed in the event of an error message by using a GCODE command from Octoprint?
(Not applicable)
(Not applicable)
(Not applicable)
octoprint-systeminfo-20240817143615.zip (91.9 KB)
Octorpint (V1.10.2), Prusa MK3S+ with MMU3 (FW V3.14.0), Firefox (V129.0.1), macOS (V14.2.1)
