Rename USB to 4 printers with the same idvendor and idproduct
I have 4 printers connected via USB on a raspberry pi 4 being 2 Ender3V2, FLSUN Q5 and QQS. All with Marlin. I already found out which USB ports they are connected to but I can't renew them.
The idvendor and idproduct is the same and idserial is 0 for the 4 printers, at least I didn't find a different number in searches.
My /etc/udev/rules.d/99-usb-serial.rules file have:
SUBSYSTEM=="tty", ATTRS{devpath}=="1.2:1.0", SYMLINK+="ENDER3-N"
SUBSYSTEM=="tty", ATTRS{devpath}=="1.1.2:1.0", SYMLINK+="ENDER3"
SUBSYSTEM=="tty", ATTRS{devpath}=="1.3:1.0", SYMLINK+="QQS"
SUBSYSTEM=="tty", ATTRS{devpath}=="1.1.3:1.0", SYMLINK+="Q5"
Another informations:
root@octopi:/home/pi# ls -l /dev/ttyUSB*
crw-rw---- 1 root dialout 188, 0 May 5 02:46 /dev/ttyUSB0
crw-rw---- 1 root dialout 188, 1 May 5 02:46 /dev/ttyUSB1
crw-rw---- 1 root dialout 188, 2 May 5 02:46 /dev/ttyUSB2
crw-rw---- 1 root dialout 188, 3 May 5 02:31 /dev/ttyUSB3
root@octopi:/home/pi# ls -la /dev/serial/by-path/
total 0
drwxr-xr-x 2 root root 120 May 5 02:47 .
drwxr-xr-x 4 root root 80 May 4 18:26 ..
lrwxrwxrwx 1 root root 13 May 4 19:07 platform-3f980000.usb-usb-0:1.1.2:1.0-port0 -> ../../ttyUSB1
lrwxrwxrwx 1 root root 13 May 5 00:45 platform-3f980000.usb-usb-0:1.1.3:1.0-port0 -> ../../ttyUSB0
lrwxrwxrwx 1 root root 13 May 5 02:47 platform-3f980000.usb-usb-0:1.2:1.0-port0 -> ../../ttyUSB3
lrwxrwxrwx 1 root root 13 May 5 00:45 platform-3f980000.usb-usb-0:1.3:1.0-port0 -> ../../ttyUSB2
dmseg
[ 2.967823] WARN::hcd_init_fiq:497: MPHI regs_base at b8810000
[ 2.972282] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.974600] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.976993] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 2.979317] Init: Port Power? op_state=1
[ 2.981547] Init: Power Port (0)
[ 2.984070] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.988685] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.991149] usb usb1: Product: DWC OTG Controller
[ 2.993509] usb usb1: Manufacturer: Linux 5.10.103-v7+ dwc_otg_hcd
[ 2.995926] usb usb1: SerialNumber: 3f980000.usb
[ 2.999114] hub 1-0:1.0: USB hub found
[ 3.001563] hub 1-0:1.0: 1 port detected
[ 3.005209] dwc_otg: FIQ enabled
[ 3.005224] dwc_otg: NAK holdoff enabled
[ 3.005247] dwc_otg: FIQ split-transaction FSM enabled
[ 3.005342] Module dwc_common_port init
[ 3.005656] usbcore: registered new interface driver usb-storage
[ 3.008351] mousedev: PS/2 mouse device common for all mice
[ 3.011971] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.017229] sdhci: Secure Digital Host Controller Interface driver
[ 3.019768] sdhci: Copyright(c) Pierre Ossman
[ 3.022886] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 3.026171] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 3.028981] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.033425] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.036475] hid: raw HID events driver (C) Jiri Kosina
[ 3.039223] usbcore: registered new interface driver usbhid
[ 3.041829] usbhid: USB HID core driver
[ 3.049738] Initializing XFRM netlink socket
[ 3.052359] NET: Registered protocol family 17
[ 3.055012] Key type dns_resolver registered
[ 3.058040] Registering SWP/SWPB emulation handler
[ 3.060544] registered taskstats version 1
[ 3.062883] Loading compiled-in X.509 certificates
[ 3.066074] Key type ._fscrypt registered
[ 3.068403] Key type .fscrypt registered
[ 3.070721] Key type fscrypt-provisioning registered
[ 3.084513] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.087033] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.094086] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.098337] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.100811] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.124831] Indeed it is in host mode hprt0 = 00021501
[ 3.151216] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.155224] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.159125] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.164242] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.187395] sdhost: log_buf @ (ptrval) (f4113000)
[ 3.239635] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.244866] of_cfs_init
[ 3.247087] of_cfs_init: OK
[ 3.265614] Waiting for root device PARTUUID=112b939d-02...
[ 3.284844] mmc1: new high speed SDIO card at address 0001
[ 3.334710] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.337077] Indeed it is in host mode hprt0 = 00001101
[ 3.342409] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.351398] mmc0: new high speed SDXC card at address aaaa
[ 3.354749] mmcblk0: mmc0:aaaa SB64G 59.5 GiB
[ 3.360662] mmcblk0: p1 p2
[ 3.402689] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.407242] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.419617] devtmpfs: mounted
[ 3.429481] Freeing unused kernel memory: 1024K
[ 3.445200] Run /sbin/init as init process
[ 3.447684] with arguments:
[ 3.447696] /sbin/init
[ 3.447706] with environment:
[ 3.447719] HOME=/
[ 3.447730] TERM=linux
[ 3.575091] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.580381] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.584044] hub 1-1:1.0: USB hub found
[ 3.586939] hub 1-1:1.0: 4 ports detected
[ 3.904750] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.035095] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 4.040730] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.044559] hub 1-1.1:1.0: USB hub found
[ 4.047597] hub 1-1.1:1.0: 3 ports detected
[ 4.051146] systemd[1]: System time before build time, advancing clock.
[ 4.144729] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 4.194816] NET: Registered protocol family 10
[ 4.199109] Segment Routing with IPv6
[ 4.277793] usb 1-1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 4.283305] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4.286222] usb 1-1.2: Product: USB Serial
[ 4.295259] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.305443] systemd[1]: Detected architecture arm.
[ 4.374735] usb 1-1.1.2: new full-speed USB device number 5 using dwc_otg
[ 4.384381] systemd[1]: Set hostname to .
[ 4.509273] usb 1-1.1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 4.525232] usb 1-1.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4.531486] usb 1-1.1.2: Product: USB Serial
[ 4.604764] usb 1-1.3: new full-speed USB device number 6 using dwc_otg
[ 4.738543] usb 1-1.3: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.63
[ 4.744849] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4.748010] usb 1-1.3: Product: USB2.0-Serial
[ 4.834781] usb 1-1.1.3: new full-speed USB device number 7 using dwc_otg
[ 4.967931] usb 1-1.1.3: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 4.973981] usb 1-1.1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4.979986] usb 1-1.1.3: Product: USB Serial
[ 5.274744] usb 1-1.1.1: new high-speed USB device number 8 using dwc_otg
[ 5.405333] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 5.409659] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.411337] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.431077] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.435481] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 5.442631] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.446258] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 5.457305] systemd[1]: Listening on udev Control Socket.
[ 5.464290] systemd[1]: Reached target Swap.
[ 5.474403] systemd[1]: Created slice system-getty.slice.
[ 5.482175] systemd[1]: Listening on udev Kernel Socket.
[ 5.490209] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.686330] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 5.730508] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 6.465373] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.606917] systemd-journald[114]: Received request to flush runtime journal from PID 1
[ 7.576079] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.578579] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 7.578605] [vc_sm_connected_init]: start
[ 7.579558] [vc_sm_connected_init]: installed successfully
[ 7.606793] mc: Linux media interface: v0.10
[ 7.681745] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.690586] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 7.730721] videodev: Linux video capture interface: v2.00
[ 7.778056] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.778119] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.780765] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.820573] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.824516] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.830187] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.833529] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 7.834162] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 7.835354] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 7.836520] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 7.836557] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.836604] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.836626] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.836648] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.836940] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.849378] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 7.849434] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 7.968081] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.098692] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 8.125204] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 8.129529] usbcore: registered new interface driver usbserial_generic
[ 8.129614] usbserial: USB Serial support registered for generic
[ 8.162305] usbcore: registered new interface driver ch341
[ 8.162407] usbserial: USB Serial support registered for ch341-uart
[ 8.162523] ch341 1-1.2:1.0: ch341-uart converter detected
[ 8.172264] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
[ 8.173456] ch341 1-1.1.2:1.0: ch341-uart converter detected
[ 8.178452] usb 1-1.1.2: ch341-uart converter now attached to ttyUSB1
[ 8.179196] ch341 1-1.3:1.0: ch341-uart converter detected
[ 8.181461] usb 1-1.3: ch341-uart converter now attached to ttyUSB2
[ 8.181846] ch341 1-1.1.3:1.0: ch341-uart converter detected
[ 8.184066] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 8.184087] usb 1-1.1.3: ch341-uart converter now attached to ttyUSB3
[ 8.184128] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 8.201987] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 8.202067] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 8.221564] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 8.222476] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 8.222524] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 8.242075] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.243895] usbcore: registered new interface driver brcmfmac
[ 8.569664] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.577573] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 10.553493] random: crng init done
[ 10.553523] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.612785] uart-pl011 3f201000.serial: no DMA platform data
[ 10.691934] 8021q: 802.1Q VLAN Support v1.8
[ 11.044792] Adding 102396k swap on /var/swap. Priority:-2 extents:22 across:149172k SSFS
[ 11.160792] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 11.501682] 8021q: adding VLAN 0 to HW filter on device eth0
[ 15.601093] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 16.681894] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 17.611895] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
[ 17.686882] Bluetooth: Core ver 2.22
[ 17.687033] NET: Registered protocol family 31
[ 17.687047] Bluetooth: HCI device and connection manager initialized
[ 17.687082] Bluetooth: HCI socket layer initialized
[ 17.687104] Bluetooth: L2CAP socket layer initialized
[ 17.687142] Bluetooth: SCO socket layer initialized
[ 17.702780] Bluetooth: HCI UART driver ver 2.3
[ 17.702799] Bluetooth: HCI UART protocol H4 registered
[ 17.702931] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 17.703779] Bluetooth: HCI UART protocol Broadcom registered
[ 18.015009] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.015021] Bluetooth: BNEP filters: protocol multicast
[ 18.015037] Bluetooth: BNEP socket layer initialized
[ 459.056216] ch341-uart ttyUSB3: usb_serial_generic_read_bulk_callback - urb stopped: -32
[ 459.056297] ch341-uart ttyUSB3: usb_serial_generic_read_bulk_callback - urb stopped: -32
[ 459.180054] usb 1-1.1.3: USB disconnect, device number 7
[ 459.180378] usb 1-1.1.3: failed to send control message: -19
[ 459.180874] ch341-uart ttyUSB3: ch341-uart converter now disconnected from ttyUSB3
[ 459.180938] ch341 1-1.1.3:1.0: device disconnected
[ 472.053461] usb 1-1.1.3: new full-speed USB device number 9 using dwc_otg
[ 472.196527] usb 1-1.1.3: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 472.196543] usb 1-1.1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 472.196550] usb 1-1.1.3: Product: USB Serial
[ 472.198848] ch341 1-1.1.3:1.0: ch341-uart converter detected
[ 472.201472] usb 1-1.1.3: ch341-uart converter now attached to ttyUSB3
[ 533.166091] usb 1-1.1.2: USB disconnect, device number 5
[ 533.166925] ch341-uart ttyUSB1: ch341-uart converter now disconnected from ttyUSB1
[ 533.167028] ch341 1-1.1.2:1.0: device disconnected
[ 1665.751893] usb 1-1.1.2: new full-speed USB device number 10 using dwc_otg
[ 1665.884902] usb 1-1.1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 1665.884915] usb 1-1.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1665.884922] usb 1-1.1.2: Product: USB Serial
[ 1665.885703] ch341 1-1.1.2:1.0: ch341-uart converter detected
[ 1665.887780] usb 1-1.1.2: ch341-uart converter now attached to ttyUSB1
[ 1849.776009] usb 1-1.1.2: USB disconnect, device number 10
[ 1849.776547] ch341-uart ttyUSB1: ch341-uart converter now disconnected from ttyUSB1
[ 1849.776627] ch341 1-1.1.2:1.0: device disconnected
[ 1851.612581] usb 1-1.1.2: new full-speed USB device number 11 using dwc_otg
[ 1851.745958] usb 1-1.1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 1851.745998] usb 1-1.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1851.746012] usb 1-1.1.2: Product: USB Serial
[ 1851.747327] ch341 1-1.1.2:1.0: ch341-uart converter detected
[ 1851.749651] usb 1-1.1.2: ch341-uart converter now attached to ttyUSB1
[ 1925.553990] usb 1-1.1.2: USB disconnect, device number 11
[ 1925.554532] ch341-uart ttyUSB1: ch341-uart converter now disconnected from ttyUSB1
[ 1925.554588] ch341 1-1.1.2:1.0: device disconnected
[ 1928.672849] usb 1-1.1.2: new full-speed USB device number 12 using dwc_otg
[ 1928.806060] usb 1-1.1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 1928.806086] usb 1-1.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1928.806100] usb 1-1.1.2: Product: USB Serial
[ 1928.807410] ch341 1-1.1.2:1.0: ch341-uart converter detected
[ 1928.812049] usb 1-1.1.2: ch341-uart converter now attached to ttyUSB1
[ 2357.684186] usb 1-1.1.2: USB disconnect, device number 12
[ 2357.685835] ch341-uart ttyUSB1: ch341-uart converter now disconnected from ttyUSB1
[ 2357.685950] ch341 1-1.1.2:1.0: device disconnected
[ 2362.586505] usb 1-1.1.2: new full-speed USB device number 13 using dwc_otg
[ 2362.719696] usb 1-1.1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 2362.719717] usb 1-1.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2362.719764] usb 1-1.1.2: Product: USB Serial
[ 2362.720927] ch341 1-1.1.2:1.0: ch341-uart converter detected
[ 2362.723556] usb 1-1.1.2: ch341-uart converter now attached to ttyUSB1
[ 2402.230035] usb 1-1.1.2: USB disconnect, device number 13
[ 2402.230625] ch341-uart ttyUSB1: ch341-uart converter now disconnected from ttyUSB1
[ 2402.230681] ch341 1-1.1.2:1.0: device disconnected
[ 2423.777041] usb 1-1.1.2: new full-speed USB device number 14 using dwc_otg
[ 2423.910318] usb 1-1.1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 2423.910340] usb 1-1.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2423.910368] usb 1-1.1.2: Product: USB Serial
[ 2423.914300] ch341 1-1.1.2:1.0: ch341-uart converter detected
[ 2423.917693] usb 1-1.1.2: ch341-uart converter now attached to ttyUSB1
this might help. you need to set your udev rules to be based on which port it's plugged into.
View the topic of "Create some udev rules for individual printer device names" in following link:
http://thomas-messmer.com/index.php/14-free-knowledge/howtos/79-setting-up-octoprint-for-multiple-printers
Even same idVendor and idProduct, but the website still add into udev rules, you can try to add them into rule.
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{devpath}=="1.2:1.0", SYMLINK+="ENDER3-N"
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{devpath}=="1.1.2:1.0", SYMLINK+="ENDER3"
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{devpath}=="1.3:1.0", SYMLINK+="QQS"
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{devpath}=="1.1.3:1.0", SYMLINK+="Q5"
Absolutely, ensure the "devpath" is correct because it's for identify each device.
Morever, only 2 devices are same bcdDevice, so you can use ATTRS(bcdDevice) to identify other 2 printers
After done, you should find out the symbolic link in /dev/tty which you specified in udev rule
Lastly, Octoprint will not get the symbolic link for connection, you need to manual input this "port" into Settings->Serial Connection->Connection->Additional serial ports.
eg. /dev/ENDER3
Hope this help.
This wouldn't be necessary I don't think if the symlinks go to ttyUSB0, ttyUSB1, etc.
FYI, as part of the octoprint_deploy script I have an additional tool for automating the creation of udev rules: octoprint_deploy/udev_rules.sh at ad7628acd5048bac3f9ccf67b5fac27e95822d80 · paukstelis/octoprint_deploy · GitHub
Perfect!!
Problem solved!
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{devpath}=="1.1.3", SYMLINK+="ttyQ5"
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{devpath}=="1.3", SYMLINK+="ttyQQS"
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{devpath}=="1.1.2", SYMLINK+="ttyENDER3"
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{devpath}=="1.2", SYMLINK+="ttyENDER3N"
