After Upgrading to Version 1.3.10 I can no longer Render Timelapse. I keep geting the following message.
Rendering timelapse failed
Rendering of timelapse LTAZ52_herringbone_small_gear-1.1-highres_20181217020103 failed with return code 127
More
/usr/bin/avconv: error while loading shared libraries: /lib/arm-linux-gnueabihf/libglib-2.0.so.0: invalid ELF header.
As im new to OctoPrint Im at a loss on how to figer out how to solve this problem.
I'm having a hard time finding the exact error/fix in context to avconv. The underlying error seems to suggest that libglib-2.0 isn't correctly installed. Sometimes this is due to a corrupted microSD card.
sudo apt-get update --fix-missing
I'm not sure which package that was included with. This isn't the correct one but I'm researching...
sudo apt-get install --reinstall libcurl3-gnutls # NOT correct version
OctoPi's build script seems to install these which could be where that comes from:
- libav-tools, libv4l-dev
- libjpeg8-dev
- libjpeg62-turbo-dev
You didn't move your microSD from one Raspberry Pi to another in all this, did you?
LOL that is funny.
I will try your suggestions and let you know what happens.
As for moving the SD card No it has never been used on a different Pi.
I'm having the same issue on a Raspberry Pi that I cloned and then modified for a different printer. I never had an issue rendering timelapses on the original version that I cloned it from. Everything else seems to work great on the cloned version that I modified except it is unable to render timelapses. It gives me the following error every time...
Rendering of timelapse JJM_Otyugh_20191011025645 failed with return code 127
REDACTED LINK TO YOUR LOCAL COMPUTER'S PRIVATE IP ADDRESS
/usr/bin/avconv: error while loading shared libraries: libpulsecommon-10.0.so: cannot open shared object file: No such file or directory
I tried what you suggested by the way and then rebooted the system but it made no difference.
Given the indicated error, I think I would try:
sudo apt-get --only-upgrade install libav-tools
If that fails then it wasn't loaded for some reason. Then you could try:
sudo apt-get install libav-tools
Thanks, for the suggestion and redacting my private IP for me.
I'm currently in the middle of a over 2 day long print but once it is complete I will try out your suggestion and let you know if it worked or not.
Well the layers shifted on my print so I had to cancel it, so I was able to try your suggestions but sadly neither of them made a difference. I am still getting that same exact error as before when I try to render one of my unrendered timelapses.
Any other ideas?
The absence of libpulsecommon-10.0.so seems to be the problem. An .so file is an object file which results from makeing a project. Something didn't succeed in an earlier step, one would assume.
Possibly removing it first then re-installing it could work. This assumes that I have the correct package that is in question here.
sudo apt-get remove libav-tools
If you had a working version of this you might even find out where this lives and then copy it over to the one that's misbehaving. It could be worth, though, grabbing a new microSD card and trying a start from square one.
