Wyze Cam V2
Timelapse rendering fails with return code 1
octoprint-systeminfo-20220327043350.zip (66.0 KB)
ffmpeg version 4.2.4-1ubuntu0.1 Copyright (c) 2000-2020 the FFmpeg developers
, built with gcc 9 (Ubuntu 9.3.0-10ubuntu2)
, configuration: --prefix=/usr --extra-version=1ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
, libavutil 56. 31.100 / 56. 31.100
, libavcodec 58. 54.100 / 58. 54.100
, libavformat 58. 29.100 / 58. 29.100
, libavdevice 58. 8.100 / 58. 8.100
, libavfilter , 7. 57.100 / 7. 57.100
, libavresample 4. 0. 0 / 4. 0. 0
, libswscale 5. 5.100 / 5. 5.100
, libswresample 3. 5.100 / 3. 5.100
, libpostproc 55. 5.100 / 55. 5.100
,[mjpeg @ 0x561f27ed9340] MJPEG packet 0xd8 too big (1488716692/1488716800), corrupt data?
,[image2 @ 0x561f27ed77c0] decoding for stream 0 failed
,[image2 @ 0x561f27ed77c0] Could not find codec parameters for stream 0 (Video: mjpeg, none(bt470bg/unknown/unknown)): unspecified size
,Consider increasing the value for the 'analyzeduration' and 'probesize' options
,Input #0, image2, from '/home/octoprint/.octoprint/timelapse/tmp/CE3_Wowstick_Stand_20220326172635-%d.jpg':
, Duration: 00:00:00.08, start: 0.000000, bitrate: N/A
, Stream #0:0: Video: mjpeg, none(bt470bg/unknown/unknown), 25 tbr, 25 tbn, 25 tbc
,Stream mapping:
, Stream #0:0 -> #0:0 (mjpeg (native) -> h264 (libx264))
,Press [q] to stop, [?] for help
,[mjpeg @ 0x561f27ee1f00] MJPEG packet 0xd8 too big (1488716692/1488716800), corrupt data?
,Error while decoding stream #0:0,: Invalid data found when processing input
,[mjpeg @ 0x561f27ee1f00] MJPEG packet 0xd8 too big (1752464276/1752464384), corrupt data?
,Error while decoding stream #0:0: Invalid data found when processing input
,frame= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbits/s speed=N/A
,Cannot determine format of input stream 0:0 after EOF
,Error marking filters as finished
,Conversion failed!
