Reported model size is far larger than reality, Octoprint generating warning popup
This problem was reported in 2022 apparently, but I have not found a solution. Prusaslicer reports a model size. I measure my part, it is a similar size. Octoprint reports the model is far outside the limits.
Added custom bounding box with a negative number for Y.
X: 250mm
Y: 210mm
Z: 270mm
Custom bounding box: based on where the filament purge line is.
X: 0min, 250max
Y: -16min, 210max
Z: 0min, 270max
n/a
octoprint-systeminfo-20260108091659.zip (8.8 KB)
Octoprint 1.11.5 Python 3.11.2. OctoPi 1.10 (build 2025.1201.130812
Core 1+, firmware 6.4.0
Safari, MacOS Sequoia 15.7.3
Physical model size: 76mm x 54mm x 12.7mm (also reported by slicer)
Position where sliced: X 190, Y 45, Z 6.35
Had similar problem with MK4S, but adding in the custom bounding box fixed it. For the Core 1+ it did not fix the problem. The physical purge line is no more than 16mm below the white box printed on the platen. The steel sheet platen white box measures 250 x 210 mm.
Octoprint reports:
Travel exceeds print volume in depth. Travel area: (0.00, -2.50, 0.00) x (249.00, 211, 40.00)
Objects bounding box: (152.22, -2.50, 0.00) x (249.00, 71.78, 15.00)
Print volume: (0.00, -16, 0) x (250.00, 210.00, 270.00)
What makes this kind of silly, is PrusaSlicer doesn't know the dimensions to fill out either, even though it's their slicer, and their printer... So I have two things to juggle.
To the best of my knowledge Core 1+ bed is 250 x 210, and max Z height is 270. That's what is loaded in the slicer. I tried searching for MAXX, MAXY, MINX, MINY stuff in the gcode, but those names are not in the file.
Anyways, is there a solution to this sort of thing? The 2022 thread closed, but I saw no solution. I saw no reference to this in the FAQ. It's dumb to turn off error checking, but false alarms are not good either. Perhaps I missed the thread where a solution is mentioned. If so, could you kindly point me to it.
The plate itself is larger than 250 x 210. That's just the white box. Physically it is 254 x 238.
I searched for Y211 and found a park command near the end of the file. It shows the following coordinates: G1 X242 Y211 F10200 ; park
The gcode is inserted by the PrusaSlicer, it's called end gcode. I have no idea why they did that...
Does this mean I should edit the bounding box for the printer (in Octoprint) to have a Y value max of 211?
For a sample of one file... Changed the bounding box YMAX from 210, to 211.01 in the Core 1 Profile. Reloaded the file, no pop up warning. Why my friends at Prusa went out of their bounding box of their own printer is beyond me. Really questionable decision.
I'll try a more complicated part to see if this is resolved.
I believe that while most 3D printers advertise the "print volume", many 3D printers are capable of moving outside the print volume for things like nozzle cleaning, limit switches, bed leveling, etc.
So you should edit the OctoPrint "Custom bounding box" to include the coordinates of any location the printer can go (be sent).
For my Lulzbot TAZ 6:
Yes, I understand the concept of the custom bounding box.
But finding those limits can be the issue. The vendors don't go out of their way to disclose this information about parking, or nozzle cleaning head position, and they may be different for multiple head machines...
So the procedure for the average Joe would be to what? Start searching a file for values of X and Y? Yes, one would use an editor, but, use the Octoprint warning values for the search?
That's what worked for me, at least this time. Just wanting to know if that's sufficient, in general for all printers.
The convoluted solution is to export a gcode file locally and look at the code for the smallest and largest positions/movement in all axes.
Seems like there ought to be a better way... But I will mark this solved, as I've now tried a couple of different files and Octoprint is not triggering the warning any more. Dunno, 3d printing is one of the domains that still is quirky. Lot's of arcane stuff to work through.
Commenting out gcode, or searching through it, when stuff like that just ought to be right in the first place. Oh well. Not a dig on Octoprint, but getting a "new printer" in Octoprint was not as simple as I thought it would be.
That being said, I want to say publicly that Octoprint is awesome, along with all the folks that developed it and support it. Seriously, it is a nice piece of software, and has made my printing life a LOT easier. Thanks for bring printing into the modern age. We'd all be using USB sticks and sneaker net still, if it weren't for Octoprint.
I'd take a more pragmatic approach... If OctoPrint reports travel exceeds print volume I'd verify and set the custom bounding box to include it. If the printer has a local screen with the ability to manually move the axis, then you could fine tune the custom box.
