Cant connect to printer after errors (having issues with a BL touch)
Well it says restart with M999, which is fine, but how can you do that if the terminal is not connected?? It does not make sense. I want to reset it like you can with Astroprint as an example.
No, will this help in this context?
Dont think it has anything to do with not being able to connect. I want to force a restart of the board remotely (like you can under AstroPrint and others)
Complete Logs
