when the filament sensor runs out the printer behaves weird. it will home and wait for a second and then it will ask on the printer if i want to resume and in octoprint it shows t0 fillament runout but then continues back to the print without me selecting any resume options and does a weird wiping motion before ultimately causing complete failure where the printer shuts down. the printer also doesnt acknowledge when i cancel the print from octoprint on the screen but the print will cancel and vice versa. I have host action enabled but it seems to not work properly I am sure I am probably just missing something but I am just trying to find a way to make sure all of the sensors on the printer are working properly through octoprint so that i am able to monitor this print that will be pushing 5 days. any and all help is greatly appreciated. if you need any more info or need me to run any more tests just let me know what and how to do it!
I have been troubleshooting it as much as possible with my limited knowledge and havent been able to find a solution i tried adding these code lines in the pause and resume gcode but it didnt change anything. pause
; relative XYZE
G91
M83
; retract filament, move Z slightly upwards
G1 Z+5 E-5 F4500
; absolute XYZE
M82
G90
; move to a safe rest position, adjust as necessary
G1 X0 Y180
resume
; relative extruder
M83
; prime nozzle
G1 E-5 F4500
G1 E5 F4500
G1 E5 F4500
; absolute E
M82
; absolute XYZ
G90
; reset E
G92 E{{ pause_position.e }}
; move back to pause position XYZ
G1 X{{ pause_position.x }} Y{{ pause_position.y }} Z{{ pause_position.z }} F4500
; reset to feed rate before pause
G1 {{ pause_position.f }}
yes it behaves the same way
no it continues with the odd behavior
octoprint-systeminfo-20241018071229.zip (351.2 KB)
octoprint-logs(10).zip (371.8 KB)
"Send: M115
Recv: FIRMWARE_NAME:Marlin 2.0.8.2 (Oct 9 2024 22:05:34) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:SanLu S9 Series EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:SERIAL_XON_XOFF:0
Recv: Cap:BINARY_FILE_TRANSFER:0
Recv: Cap:EEPROM:1
Recv: Cap:VOLUMETRIC:1
Recv: Cap:AUTOREPORT_POS:0
Recv: Cap:AUTOREPORT_TEMP:0
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:1
Recv: Cap:RUNOUT:1
Recv: Cap:Z_PROBE:1
Recv: Cap:LEVELING_DATA:1
Recv: Cap:BUILD_PERCENT:0
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:0
Recv: Cap:HOST_ACTION_COMMANDS:1
Recv: Cap:PROMPT_SUPPORT:1
Recv: Cap:SDCARD:1
Recv: Cap:REPEAT:0
Recv: Cap:SD_WRITE:1
Recv: Cap:AUTOREPORT_SD_STATUS:0
Recv: Cap:LONG_FILENAME:0
Recv: Cap:THERMAL_PROTECTION:1
Recv: Cap:MOTION_MODES:0
Recv: Cap:ARCS:1
Recv: Cap:BABYSTEPPING:1
Recv: Cap:CHAMBER_TEMPERATURE:0
Recv: Cap:COOLER_TEMPERATURE:0
Recv: Cap:MEATPACK:0
Recv: ok"
This is the block of code that comes out when the sensor detects runout.
"Recv: //action:prompt_end
Recv: //action:prompt_begin FilamentRunout T0
Recv: //action:prompt_show
Recv: //action:paused filament_runout 0
Printer signalled that it paused, switching state...
Changing monitoring state from "Printing" to "Pausing"
Recv: echo:busy: processing
Recv: ok
Changing monitoring state from "Pausing" to "Paused"
Send: M105
Recv: Writing to file: /PLR
Pausing on request of the printer...
Recv: X:0.00 Y:0.00 Z:5.00 E:68.37 Count X:0 Y:0 Z:2000
Recv: ok
Send: M105
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.38 /245.00 B:90.68 /90.00 @:74 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Send: M105
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.61 /245.00 B:90.75 /90.00 @:70 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.69 /245.00 B:90.73 /90.00 @:69 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.69 /245.00 B:90.74 /90.00 @:69 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.84 /245.00 B:90.73 /90.00 @:67 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.84 /245.00 B:90.70 /90.00 @:67 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.77 /245.00 B:90.70 /90.00 @:69 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.00 /245.00 B:90.68 /90.00 @:64 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.00 /245.00 B:90.68 /90.00 @:65 B@:0
Send: M105
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.00 /245.00 B:90.65 /90.00 @:66 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.00 /245.00 B:90.61 /90.00 @:66 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.08 /245.00 B:90.54 /90.00 @:64 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.08 /245.00 B:90.54 /90.00 @:65 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.08 /245.00 B:90.50 /90.00 @:65 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.31 /245.00 B:90.45 /90.00 @:60 B@:0
Recv: ok
Recv: ok
Send: M105
Recv: ok
Recv: ok T:245.47 /245.00 B:90.41 /90.00 @:58 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.31 /245.00 B:90.41 /90.00 @:61 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.55 /245.00 B:90.40 /90.00 @:57 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.94 /245.00 B:90.28 /90.00 @:50 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:246.02 /245.00 B:90.27 /90.00 @:48 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.78 /245.00 B:90.27 /90.00 @:53 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:246.09 /245.00 B:90.18 /90.00 @:47 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.86 /245.00 B:90.14 /90.00 @:52 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:246.02 /245.00 B:90.14 /90.00 @:49 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.94 /245.00 B:90.03 /90.00 @:51 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.86 /245.00 B:90.00 /90.00 @:52 B@:0
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.63 /245.00 B:90.00 /90.00 @:56 B@:0
Recv: ok
Recv: ok
Send: M105
Recv: ok
Recv: ok T:246.25 /245.00 B:89.96 /90.00 @:44 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:246.25 /245.00 B:89.86 /90.00 @:44 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.86 /245.00 B:89.86 /90.00 @:52 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.78 /245.00 B:89.78 /90.00 @:53 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.94 /245.00 B:89.73 /90.00 @:50 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.70 /245.00 B:89.73 /90.00 @:54 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.55 /245.00 B:89.66 /90.00 @:56 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.31 /245.00 B:89.62 /90.00 @:60 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.00 /245.00 B:89.59 /90.00 @:65 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.00 /245.00 B:89.59 /90.00 @:64 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.00 /245.00 B:89.56 /90.00 @:64 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.00 /245.00 B:89.50 /90.00 @:64 B@:127
Recv: ok
Recv: ok
Send: M105
Recv: ok
Recv: ok T:245.00 /245.00 B:89.46 /90.00 @:63 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:245.00 /245.00 B:89.46 /90.00 @:62 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.92 /245.00 B:89.43 /90.00 @:63 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.77 /245.00 B:89.35 /90.00 @:66 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.53 /245.00 B:89.33 /90.00 @:70 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.84 /245.00 B:89.32 /90.00 @:64 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.69 /245.00 B:89.32 /90.00 @:67 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.14 /245.00 B:89.32 /90.00 @:76 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.61 /245.00 B:89.32 /90.00 @:67 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.53 /245.00 B:89.32 /90.00 @:69 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.30 /245.00 B:89.28 /90.00 @:73 B@:127
Recv: ok
Send: M105
Recv: ok
Recv: ok
Recv: ok T:244.14 /245.00 B:89.30 /90.00 @:75 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.14 /245.00 B:89.26 /90.00 @:75 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.22 /245.00 B:89.25 /90.00 @:74 B@:127
Recv: ok
Recv: ok
Recv: ok
Recv: ok T:244.30 /245.00 B:89.26 /90.00 @:72 B@:127
Send: M105
Recv: ok T:244.77 /245.00 B:89.19 /90.00 @:65 B@:127
Send: M105
Recv: ok T:245.00 /245.00 B:89.25 /90.00 @:63 B@:127
Send: M105
Recv: ok T:245.00 /245.00 B:89.32 /90.00 @:64 B@:127
Send: M105
Recv: ok T:245.23 /245.00 B:89.54 /90.00 @:60 B@:127
Send: M105
Recv: ok T:245.16 /245.00 B:89.73 /90.00 @:61 B@:127"
