So, i decided to share my Octoprint instance through public interface, but got issue with actual connection via https.
Step 1. Configuring nginx.
Installed nginx and created config:
# /etc/nginx/sites-availalble/octoprint
server {
server_name octo.hostname.com;
location / {
proxy_pass http://localhost:1337/;
proxy_set_header Host $host;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_http_version 1.1;
client_max_body_size 0;
So now it is having connection via local.ip.address:1337 and http:// octo.hostname.com. But the thing is ssl certificate warning that i decided to get rid of.
In order of that:
Step 2. Getting actual ssl certificate using certbot.
So i've installed certbot and certbot-nginx packages and performed:
# certbot --nginx
which asked me for the server that i want get ssl certificates for. The only and actual server in the list was octoprint.
After performing that procedure, the nginx configuration file looks like that:
server {
listen 80;
location / {
# Added block below after reading article:
# https://community.octoprint.org/t/reverse-proxy-configuration-examples/1107
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root html;
listen 443 ssl; # managed by Certbot
ssl_certificate path/to/fullchain.pem; # managed by Certbot
ssl_certificate_key path/to/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = octo.hostname.com) {
return 301 https://$host$request_uri;
} # managed by Certbot
listen 80;
return 404; # managed by Certbot
Looks fine to me, although i barely understand all the things "under-the-hood".
But now, when i am going to my browser and typing octo.hostname.com:
- from the local subnet browser redirects me to my router config page, and there is actually https;
- from the public network (using mobile LTE) page won't load.
The local.ip.address:1337 still works fine, but again it's over http and there is certificate warning.
Trying to solve this issue, i've asked a GPT about octoprint configuration. The answer was to add:
ssl:
cert: path/to/fullchain.pem
key: path/to/privkey.pem
under "server" block of octoprint's config.yaml. No result.
Yes.
No.
octoprint-systeminfo-20240215114945.zip (80.7 KB)
Octoprint and nginx instances is running on laptop with Arch Linux os, outside of any containers. shame ![]()
Printer model is Ender 3.
Browsers: firefox for desktop, chrome for mobile.
Router: Huawei RT-GM-2.
DNS name and subdomain is claimed properly, as conclusion of step 1 says to me. There is actual DNS name and static IP, not the DDNS or VPN.
