I need to rotate the screen 180 degrees. I can't mount the screen in the current configuration because the USB cables interfere with other components.
I attempted to use the commands
sudo ./install_uc_touch_180.sh
as shown on the UCTRONICS guide, but saw no change.
I am running OctoDash on this touch screen.
              Could you please post a link to that guide?
Is the screen, the touch and OctoDash working right now (besides of the wrong orientation)?
              Here is the UCTRONICS install guide:
There is also a wiki for both the HDMI version and the standard version
standard: UCTRONICS LCD35 RPI (SPI interface) - UCTRONICS
HDMI: UCTRONICS LCD35 HDMI RPI (HDMI interface) - UCTRONICS
The standard version wiki has code to rotate the screen 180
 cd UCTRONICS_LCD35_RPI
 sudo chmod 777 UCTRONICS_LCD35_rotation_180_install
 sudo ./UCTRONICS_LCD35_rotation_180_install
I tried this code and had no luck. I also tried using UCTRONICS_LCD35_HDMI in place of just UCTRONICS_LCD35, as this is the only change in the directory names, but that didn't work either.
Yes, other than the screen rotation, everything works great.
Thank you!
