When printing with raspberry pi 3B using octoprint (touchui enabled), small circles/holes you can hear that instead of a continuous circle, it prints in "points" (like stuttering).
I seriously don't know how to describe this, so here are pictures how it looks when printed from RPi and from my PC.
I guess that this might be the same thing: https://github.com/foosel/OctoPrint/issues/450
Nothing, as everything works great when printing it from PC (using Cura, but the same gcode). I really don't know what can cause it.
OctoPrint: 1.3.10
OctoPi: 0.16.0
Printer: Kossel delta "clone"
Firmware: Marlin-AC-G-force9-AC
octoprint.log: octoprint.log (61.0 KB)
Can you share the gcode and stl?
- Guess: The Kossel probably uses an Arduino Mega 2560 (8-bit) controller board
- This is a delta printer which requires a lot fo mathematical conversions from cartesian coordinates
That alone is a recipe for shredding/blobbing/stuttering.
And then you've added extra processing needs to your Raspberry Pi 3B by adding the PIXEL/Desktop plus browser on top of this, possibly making the Pi unresponsive on its side of the communications.
Read through the many things that people did on those two long issue threads.
