RPi 5 + Octopi + Pi Camera 1.3 (OV5647)
I am trying to set up a Raspberry Pi 5 to replace a dying Rpi3+ reusing the Pi camera 1.3 (ov5647) but I cannot get the video stream to work in Octoprint.
I have tried multiple times both versions of Octopi using Raspberry pi imager up to date to no avail.
The camera is detected by the system, I can take a test picture, rpicam-hello is working too but no streaming in Octoprint.
rpicam-hello --list-cameras
Available cameras
0 : ov5647 [2592x1944 10-bit GBRG] (/base/axi/pcie@120000/rp1/i2c@80000/ov5647@36)
    Modes: 'SGBRG10_CSI2P' : 640x480 [58.92 fps - (16, 0)/2560x1920 crop]
                             1296x972 [43.25 fps - (0, 0)/2592x1944 crop]
                             1920x1080 [30.62 fps - (348, 434)/1928x1080 crop]
                             2592x1944 [15.63 fps - (0, 0)/2592x1944 crop]
[0:52:44.238411179] [1662]  INFO Camera camera_manager.cpp:330 libcamera v0.5.2+99-bfd68f78
[0:52:44.251795417] [1665]  INFO RPI pisp.cpp:720 libpisp version v1.2.1 981977ff21f3 29-04-2025 (14:17:26)
[0:52:44.260884724] [1665]  INFO IPAProxy ipa_proxy.cpp:180 Using tuning file /usr/share/libcamera/ipa/rpi/pisp/ov5647.json
[0:52:44.275060979] [1665]  INFO Camera camera_manager.cpp:220 Adding camera '/base/axi/pcie@120000/rp1/i2c@80000/ov5647@36' for pipeline handler rpi/pisp
[0:52:44.275102702] [1665]  INFO RPI pisp.cpp:1179 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/ov5647@36 to CFE device /dev/media2 and ISP device /dev/media0 using PiSP variant BCM2712_C0
WARNING: Capture will not make use of temporal denoise
         Consider using the --zsl option for best results, for example:
Made DRM preview window
Preview window unavailable
Mode selection for 1296:972:12:P
    SGBRG10_CSI2P,640x480/0 - Score: 3296
    SGBRG10_CSI2P,1296x972/0 - Score: 1000
    SGBRG10_CSI2P,1920x1080/0 - Score: 1349.67
    SGBRG10_CSI2P,2592x1944/0 - Score: 1567
Stream configuration adjusted
[0:52:44.513376843] [1662]  INFO Camera camera.cpp:1215 configuring streams: (0) 1296x972-YUV420/sYCC (1) 1296x972-GBRG_PISP_COMP1/RAW
[0:52:44.513503731] [1665]  INFO RPI pisp.cpp:1483 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/ov5647@36 - Selected sensor format: 1296x972-SGBRG10_1X10/RAW - Selected CFE format: 1296x972-PC1g/RAW
#10 (0.00 fps) exp 33222.00 ag 8.00 dg 1.00
#11 (30.02 fps) exp 33222.00 ag 8.00 dg 1.00
#12 (30.01 fps) exp 33222.00 ag 8.00 dg 1.00
<.... SNIPPED...>
Mode selection for 2592:1944:12:P
    SGBRG10_CSI2P,640x480/0 - Score: 7832
    SGBRG10_CSI2P,1296x972/0 - Score: 5536
    SGBRG10_CSI2P,1920x1080/0 - Score: 4238.67
    SGBRG10_CSI2P,2592x1944/0 - Score: 1000
[0:52:49.533226606] [1662]  INFO Camera camera.cpp:1215 configuring streams: (0) 2592x1944-YUV420/sYCC (1) 2592x1944-GBRG_PISP_COMP1/RAW
[0:52:49.538794255] [1665]  INFO RPI pisp.cpp:1483 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/ov5647@36 - Selected sensor format: 2592x1944-SGBRG10_1X10/RAW - Selected CFE format: 2592x1944-PC1g/RAW
Still capture image received
All terminal information are from an ssh terminal, no redirection of anything.
dmesg | grep ov5647
[    1.909380] platform 1f00128000.csi: Fixed dependency cycle(s) with /axi/pcie@120000/rp1/i2c@80000/ov5647@36
[    5.502151] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/ov5647@36
[    5.502176] rp1-cfe 1f00128000.csi: Using sensor ov5647 4-0036 for capture
rpicam-hello
[0:13:27.738047332] [1500]  INFO Camera camera_manager.cpp:330 libcamera v0.5.2+99-bfd68f78
[0:13:27.751660921] [1505]  INFO RPI pisp.cpp:720 libpisp version v1.2.1 981977ff21f3 29-04-2025 (14:17:26)
[0:13:27.760737634] [1505]  INFO IPAProxy ipa_proxy.cpp:180 Using tuning file /usr/share/libcamera/ipa/rpi/pisp/ov5647.json
[0:13:27.775011380] [1505]  INFO Camera camera_manager.cpp:220 Adding camera '/base/axi/pcie@120000/rp1/i2c@80000/ov5647@36' for pipeline handler rpi/pisp
[0:13:27.775056029] [1505]  INFO RPI pisp.cpp:1179 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/ov5647@36 to CFE device /dev/media2 and ISP device /dev/media0 using PiSP variant BCM2712_C0
[0:13:28.017923009] [1500]  INFO Camera camera.cpp:1215 configuring streams: (0) 1296x972-YUV420/sYCC (1) 1296x972-GBRG_PISP_COMP1/RAW
[0:13:28.018049177] [1505]  INFO RPI pisp.cpp:1483 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/ov5647@36 - Selected sensor format: 1296x972-SGBRG10_1X10/RAW - Selected CFE format: 1296x972-PC1g/RAW
#12 (30.02 fps) exp 33222.00 ag 8.00 dg 1.00
#13 (30.01 fps) exp 33222.00 ag 8.00 dg 1.00
#14 (30.02 fps) exp 33222.00 ag 8.00 dg 1.00
libcamera-hello --list-cameras
-bash: libcamera-hello: command not found
Reinstall Octopi from scratch switching from the 2 versions multiple times and trying the streaming in Octoprint after editing the /boot/firmware/config.txt to add the dtoverlay=ov5647 line and disabling the camera auto-detect.
In the stable version, the webcam logs showed that it could not find a USB camera.
Starting up webcamDaemon...
cfg_file:      /boot/firmware/octopi.txt
camera:        auto
usb options:   -r 640x480 -f 10
raspi options: -fps 10
http options:  -w ./www-octopi -n --listen 127.0.0.1
Explicitly set USB device:
Found video devices:
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video24
/dev/video25
/dev/video26
/dev/video27
/dev/video28
/dev/video29
/dev/video30
/dev/video31
/dev/video32
/dev/video33
/dev/video34
/dev/video35
config file='/boot/firmware/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video19
<13>Nov 19 08:40:10 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video19
MJPG Streamer Version.: 2.0
 i: Using V4L2 device.: /dev/video19
 i: Frames Per Second.: 10
 i: Format............: JPEG
Error opening device /dev/video19: video capture not supported.
 i: init_VideoIn failed
Done bringing up all configured video devices
Scanning again in two minutes
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video24
/dev/video25
/dev/video26
/dev/video27
/dev/video28
/dev/video29
/dev/video30
/dev/video31
/dev/video32
/dev/video33
/dev/video34
/dev/video35
<13>Nov 28 12:12:59 root: Starting USB webcam
In the new video stack version, the camera is detected without touching anything but no streaming and the journal logs are useless to say the least but it seems, it is also looking for a USB camera.
-- Boot b123c2c82ffb48738325562e583641dc --
Nov 28 17:09:15 rpi5-octopi systemd[1]: Starting camera-streamer.service - camera-streamer...
Nov 28 17:09:15 rpi5-octopi camera-streamer-control[670]: Running start for camera-streamer-libcamera.service...
Nov 28 17:09:15 rpi5-octopi camera-streamer-control[670]: ... done.
Nov 28 17:09:15 rpi5-octopi camera-streamer-control[670]: Adding path unit for autolaunch of camera-streamer-usb@default
Nov 28 17:09:16 rpi5-octopi camera-streamer-control[670]: Running start for camera-streamer-usb-default.path...
Nov 28 17:09:16 rpi5-octopi camera-streamer-control[670]: ... done.
Nov 28 17:09:16 rpi5-octopi systemd[1]: Finished camera-streamer.service - camera-streamer.
No, it is a fresh install from scratch, nothing added, no restore.
octoprint-systeminfo-20251128174046.zip (17.9 KB)
OctoPrint version: 1.11.4, OctoPi version: 1.1.0, browser: Safari 26.1, operating system: Mac OS 26.1 , Camera: Raspberry Pi Camera V1.3 (OV5647 sensor)
Unfortunately, the Raspberry Pi 5 is missing a video hardware encoder that exists in previous versions. This missing encoder has caused many of the "camera solutions" to fail including the ones included with both OctoPi images.
While the following threads are mostly focused on the Camera Module 3, I believe they would apply equally to the Camera Module 1.3.
https://community.octoprint.org/t/pi5-raspberry-pi-module-3/62453
https://github.com/ayufan/camera-streamer/issues/149
https://github.com/OctoPrint/OctoPi-UpToDate/issues/19
There are additional threads in this forum that discuss the RPi 5 (or RPi5) as a suitable host for OctoPrint with the general concensus that it is overkill. At this point in time, an RPi 4 is a much better choice.
RPi4 sure is better than RPi5 because Module 3 camera not working in Octoprint. But without this camera RPi5 is example much faster to start because you can use NVMe SSD. Start take only few seconds and with card 1-2 minutes. I hope that somebody can fix this problem in the future...
This was actually discussed in the latest OctoPrint on Air at time stamp 26:41.
https://youtu.be/PwVG1EKRT-4?si=zC096kNl57c9Zct1&t=1601
It may be an OctoPi specific issue, so you could install pi os lite and then use octoprint_deploy script to install OctoPrint and it might work out better.
It really seems to be specific to mjpeg-streamer with the RPi5. I went another route as I am not really into headache time searching for a root cause analysis.
I installed Raspi 64bits and used the octoprint_deploy to install Octoprint. Then I tried several mjpeg streamer solutions with no luck, the RPi5 uses software h264 encoding and all these software are written for hardware encoding and using the rpicams as USB devices which does not work this way on RPi5.
I finally opted for a much easier way of streaming the camera, even 2 at once for different angles, using MediaMtx. It is super easy to install and set up. I had to disable the mjpeg-streamer and install the Webcam-iFrame plugin to get the video streamed in Octoprint.
Another awesome plugin, OctoPrint-MultiCamView, gives me the ability to see multiple cameras at once on the same page via a new tab in Octoprint, including iframe streamings.
For now, it will do as long as I am testing 2 cameras at once, I may try to investigate what is blocking mjpeg-streamer later but I actually prefer the low latency, low resources, super easy to configure and no headache MediaMtx solution.
Yeah, my other recommendation was going to be go2rtc as a potential alternative.
I have been testing MediaMtx and go2rtc for a few days also, it "works" on rpi5 but due to the lack of hardware encoder, getting a high definition video is tricky as the cpu kicks over 270% when using the maximum resolution of either a rpi cam V1.3 or rpi cam V3, it is not a viable solution for wide angle streaming. It's a bummer, my rpi 3 does better at streaming!!
I will try next the mjpeg-streamer fork (GitHub - ArduCAM/mjpg-streamer: Fork of http://sourceforge.net/projects/mjpg-streamer/) to see it does any good but I think the Rpi 5 is definitely a lost cause for video streaming, I really don't get why they put 2 camera inputs if even 1 hardly get the job done! It's really sad as the rpi 5 is really fast.
There's a pretty good break down over on this issue from @geerlingguy
Well, after hours of surfing, I found a way of getting the full resolution of both camera using go2rtc and using only around 10-12% of CPU using the option " --mode 2592:1944 " instead of " --width 2592 --height 1944" in rpicam-vid command line, now, I have to find why the video freezes now and then repetitively.
My current go2rtc.yaml looks like this:
api:
  origin: "*"
streams:
  pi5cam-1: exec:rpicam-vid -t 0 --camera 0 --mode 2592:1944 --codec libav --libav-video-codec-opts "profile=baseline" --libav-format mpegts -o -
  pi5cam_V3: exec:rpicam-vid -t 0 --camera 1 --mode 4608:2592 --codec libav --libav-video-codec-opts "profile=baseline" --libav-format mpegts -o -
That's better, mode option was in my comment at the end of that issue that's previously linked.
After several days of testing and parameters adjustments, I still have an issue which I reported to Go2rtc's Github, the stream randomly freezes for 1-3 seconds, stops and restarts for both camera even if using only one camera. I don't know if is is because of Raspi OS Trixie 64 bits or anything else, I did not observe anything CPU related to the stream restart, it just stops and restarts, freezing the ssh terminal in the meantime. I was watching it closely with a monitor connected to it with a ping rolling without interruption so it is not network related nor any error message in system or application logs.
After connecting the Raspberry Pi 5 to ethernet, the video stream in rock solid so there is something going on with the Wifi on Rpi 5.
One question to jneilliii, did you manage to get the video stream in the mobile app Octopod with your Go2rtc plugin?
I don't have iPhone so don't use OctoPod, but I know OctoApp has made concessions for my go2rtc plugin.
