Raspberry Pi Camera Module V2-8 Megapixel,1080p (RPI-CAM-V2)
I know this is caused by the print bed power nearby the camera ribbon. Does anyone know if I shield the print bed cables if it would fix it or is moving the ribbon the only option.
So, what is the actual issue?
I would wrap the ribbon cable in grounded tin foil to test if it makes a difference
You could also consider a ferrite core with the cable wrapped through it. It might also have some affect in addition to the foil shielding suggestion.
