I exchanged my Raspberry PI 4b with a CM5 Module to get a SSD and also ext. Ant. With OctoPI 1.1.0 (beta) created also for CM5 modules it breaks GPIO functionality of many plugins like enclosure or GPIO-Status. This seems caused by the standard library RPi.GPIO that is not enhanced anymore but not sure if that is 100% true as I cannot get it running again installing drop-in replacements.
Created a ticket for OctoPI as a workaround should be integrated there if possible to support old plugins out-of-the-box. CM5 or rPI 5 GPIOs are not supported because RPi.GPIO lib does not support it Β· Issue #848 Β· guysoft/OctoPi
2025-03-16 15:02:48,758 - octoprint.plugins.SlicerEstimator - DEBUG - Event received: ClientAuthed
2025-03-16 15:02:48,758 - octoprint.plugins.SlicerEstimator - DEBUG - Payload: {'username': 'octopi', 'remoteAddress': '192.168.177.109'}
2025-03-16 15:02:48,769 - octoprint.plugins.enclosure - INFO - mqtt helpers not found. mqtt functions won't work
2025-03-16 15:02:48,771 - octoprint.plugins.enclosure - INFO - Setting GPIO pin 5 as OUTPUT with initial value: 1
2025-03-16 15:02:48,772 - octoprint.plugins.enclosure - WARNING - An exception of type RuntimeError occurred on log_error. Arguments:
('Cannot determine SOC peripheral base address',)
  File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint_enclosure/__init__.py", line 1570, in configure_gpio
    GPIO.setup(pin, GPIO.OUT, initial=initial_value)
RuntimeError: Cannot determine SOC peripheral base address
2025-03-16 15:02:48,777 - octoprint.plugins.enclosure - WARNING - An exception of type RuntimeError occurred on log_error. Arguments:
('You must setup() the GPIO channel first',)
  File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint_enclosure/__init__.py", line 953, in update_ui_outputs
    val = GPIO.input(pin) if not output['active_low'] else (not GPIO.input(pin))
RuntimeError: You must setup() the GPIO channel first
Tried to install an drop-in replacement like GitHub - phylax2020/RPi.GPIO: RPi.GPIO wrapper for WiringPi or RPi.IGPIO on system level with APT and also in the venv with PIP without success.
No, as it is related to the plugins or e.g. Debian (OctoPI) installation.
octoprint-systeminfo-20250316145347.zip (30.7 KB)
OctoPrint 1.10.3, OctoPI 1.1.0 beta - build 10.03.2025, Raspberry CM5 Lite
