I had my printer connected to the RPI with Octoprint, and it was working perfectly. I added a BLTouch to the printer and thus, edited the Marlin 2.0 firmware and flashed to the SD card again. Since then, Octoprint has been giving me the same error.
I have read other complaints about octoprint not being able to recognize the serial port due to incorrect USB connection. So, I tried multiple USB cables in order to solve it. Unfortunately, nothing has worked. I also checked the code from the Marlin 2.0 firmware to make sure I had the proper baudrate set for my particular printer. It is correct. There were other posts about the order in which I should power on the devices (i.e. first the RPI and its USB connection to the printer, then the power to the printer itself). I tried those options, with no luck either.
Complete Logs
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /dev/ttyUSB0, baudrate 250000
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0x67adf470, open=True>(port='/dev/ttyUSB0', baudrate=250000, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
No answer from the printer within the connection timeout, trying another hello
Send: N0 M110 N0125
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
