Initially my Webcam stopped working which I assumed was due to the ribbon cable coming loose after moving my printer into an enclosure in my garage.
I tried the connections, but decided to rebuild my Raspberry Pi Zero 2W completely from scratch. Using Raspberry Imager I did a fresh install, followed the Prusa guide for setting up as it is plugged directly into the main board and I had no connection to the printer at all and no web cam
Rebuilt Pi Zero2 several times, including a completely fresh install that went through the initial Setup script
Followed this guide with all optional settings Octoprint - Configuration and install | Prusa Knowledge Base
Removing the camera completely
Checked serial ports /dev/ttyAMA0 and /dev/s0 exist
Added the following to boot/config.txt
dtoverlay=pi3-miniuart-bt
dtoverlay=disable-bt
enable_uart=1
I am beginning to wonder if my Zero 2W has a fault, as I can’t get either the webcam or the serial port to work.
Yes, made no difference
serial.log (148 Bytes)
octoprint.log (47.8 KB)
tornado.log (22.0 KB)
haproxy.log (40.5 KB)
webcamd.log (2.3 KB)
System Info
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.5 Safari/605.1.15
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1000.0
env.hardware.ram: 380948480
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi Zero 2 W Rev 1.0
env.plugins.pi_support.octopi_version: 1.0.0
env.plugins.pi_support.octopiuptodate_build: 1.0.0-1.9.0-20230523082504
env.python.pip: 22.3
env.python.version: 3.9.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2023-06-18T09:21:19Z
octoprint.last_safe_mode.reason: settings
octoprint.safe_mode: False
octoprint.version: 1.9.0
systeminfo.generated: 2023-06-18T09:44:02Z
systeminfo.generator: zipapi
