Hello everyone,
I have attempted to connect a RPi Zero board to my Prusa MK3S+ machine running Octoprint as described in this post: PrusaPrint (Rpi Zero and Octoprint) | Prusa Knowledge Base
This setup worked fine but then I attempted to add 4 x USB Hub to the RPi Zero but this caused the Prusa printer not to boot when I switched on the PSU. The LCD remained dark and it seemed like the printer received no power. I have tried to re-solder the pins and tried with different board but it did not help.
This is the USB Hub I used: WaveShare USB HUB HAT (B) for Raspberry Pi Series, 4x USB 2.0 Ports 2, 7,99 β¬
I have read that the Einsy board can provide up to 2A over that connection, however the RPi draws very little (around 400mA) and there is nothing connected to the USB hub that would draw extra electricity.
The setup works fine when I provide power to the RPi over my laptops USB port.
Currently, I have an idea to connect the RPi to the PSU unit over a 24 to 5 V converter but I'm not sure if it'll work properly since the RPi is already connected to the 5V on the Einsy board. I am trying to keep the setup lean and clean and this approach has additional components which I don't prefer but will have to use if there is no other way.
Do you know what could be the issue and how to fix it? Is the idea to add PSU power to RPi dangerous to the board?
Thanks for the replies ![]()
