Trying to run a python script with the "events" under "config.yaml" to trigger a bool in my S7-1200 that is then going to communicate with a UR 5e robot. But I can't get my raspberry pi to execute my python script.
First of the documentation is kinda bad tryed to follow the example of the offical documentation Events β OctoPrint master documentation.
That made it only worse so when i copied that and restarted the system everything when wrong. I could not connect to the octoprint browser.
Then i tried the plugin "Action command". Did not work but I looked in the "config.yaml" file and saw that the plugin used "action" insteed of using the "event" so I tried that and it worked.
So now i can at least connect to the browser but I can't get it to work still.
I have provided the full file path to my python script but it does not change anything.
Well we have a ZYYX Pro II printer, octoprint 1.6.0, Raspberry Pi 4 Model B Rev 1.1,
