Hey all,
I'm the developer of OctoPod (iOS open source client) and I'm troubleshooting some 'random' error that I'm getting in the client when reading from the websocket. FYI, I'm using Starscream (also open source) for reading from the websocket.
I'm testing with OctoPrint latest from repo and this also happens with 3.1.8. I do not remember seeing this with 3.1.6 or earlier but maybe it was happening there as well. IIRC, I saw this error also with 3.1.7. I haven't had time to start up an old version to test this. Anyway, the client connects to the raw websocket.
The error I get on the client is that it randomly reads "corrupted" data from the websocket. This is an example of what it got reading from the websocket:
"tTimeLeft": null, "printTimeOriRecv: ok", "1 M19"Send:11N8 M83*16",rigin": null}}}{"current": {"logs": ["Recv: w452"]820offsets": {}, "serverTime": .......
At that same time, OctoPrint printed this WARNING message:
octoprint.server.util.sockjs - WARNING - Could not send message to client 192.168.252.3: Existing exports of data: object cannot be re-sized
I'm using PyCharm to run the server and have some breakpoints that do not suspend but print data being sent over websockets. These are the 2 things that OctoPrint was trying to send right before the warning was printed to the console. All previous messages before these 2 things were correctly received by the client.
{'event': {'type': 'Home', 'payload': None}}
{'current': {'logs': [u'Recv: ok', u'Send: N11 M190 S60*110', u'Recv: wait'], 'offsets': <frozendict {}>, 'serverTime': 1539227642.694162, 'busyFiles': [{'origin': 'local', 'path': u'PLA_20x20x15_calibration-shape.gcode'}], 'messages': [], 'job': <frozendict {'averagePrintTime': 23.049983152976402, 'lastPrintTime': 20.89697003364563, 'user': '_api', 'file': <frozendict {'origin': 'local', 'name': u'PLA_20x20x15_calibration-shape.gcode', 'date': 1539058651, 'path': u'PLA_20x20x15_calibration-shape.gcode', 'display': u'PLA 20x20x15_calibration-shape.gcode', 'size': 29007}>, 'estimatedPrintTime': 122.75602841248207, 'filament': {u'tool0': {u'volume': 0.18941659711422423, u'length': 78.75026999999955}}}>, 'temps': [<frozendict {'tool0': <frozendict {'actual': 160.0, 'target': 160.0}>, 'bed': <frozendict {'actual': 21.3, 'target': 60.0}>, 'time': 1539227642}>], 'state': <frozendict {'text': 'Printing', 'flags': <frozendict {'cancelling': False, 'paused': False, 'operational': True, 'pausing': False, 'printing': True, 'resuming': False, 'sdReady': True, 'error': False, 'ready': False, 'finishing': False, 'closedOrError': False}>}>, 'currentZ': None, 'progress': <frozendict {'completion': 3.0165132554211054, 'printTimeLeftOrigin': 'average', 'printTime': 15, 'printTimeLeft': 22, 'filepos': 875}>}}
OctoPrint was regularly sending {'current' ..} notifications just fine. And then an {'event'} notification appeared and ruined the party.
I did a quick google search on that WARNING and found this thread: https://github.com/tornadoweb/tornado/issues/2271. I wonder if OctoPrint has another thread, other than the original ioloop thread writing to the websocket as mentioned in that issue. And I also wonder if this is the root cause for what I'm receiving on the client side.
Thoughts?
Thanks,
Gaston
