2019-10-07 17:35:30,290 - octoprint.server - INFO - ------------------------------------------------------------------------------
2019-10-07 17:35:33,588 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 2.8e+07s
2019-10-07 17:42:41,272 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.1.252', 1900), not sending a M-SEARCH reply
2019-10-07 17:42:47,170 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.1.252', 1900), not sending a M-SEARCH reply
2019-10-07 17:37:10,377 - octoprint.startup - INFO - ******************************************************************************
2019-10-07 17:37:10,379 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2019-10-07 17:37:10,381 - octoprint.startup - INFO - ******************************************************************************
2019-10-07 17:37:11,806 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-10-07 17:37:14,629 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-10-07 17:37:14,766 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-10-07 17:37:14,821 - octoprint.server - INFO - Intermediary server started
2019-10-07 17:37:14,822 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-10-07 17:37:15,433 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-10-07 17:37:15,519 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-10-07 17:37:15,522 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-10-07 17:37:15,586 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-10-07 17:37:17,903 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-10-07 17:37:19,523 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-10-07 17:37:19,525 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-10-07 17:37:19,526 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-10-07 17:37:19,531 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2019-10-07 17:37:19,541 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
2019-10-07 17:37:19,562 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
2019-10-07 17:37:19,572 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-10-07 17:37:19,589 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-10-07 17:37:20,007 - octoprint.server - INFO - Shutting down intermediary server...
2019-10-07 17:37:20,354 - octoprint.server - INFO - Intermediary server shut down
2019-10-07 17:37:20,357 - octoprint.events - INFO - Processing startup event, this is our first event
2019-10-07 17:37:20,359 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-10-07 17:37:20,361 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-10-07 17:37:20,366 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-10-07 17:37:20,384 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-10-07 17:37:20,398 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-10-07 17:37:20,408 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-10-07 17:37:20,425 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-10-07 17:37:22,104 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-10-07 17:37:22,106 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-10-07 17:37:22,107 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-10-07 17:37:28,241 - octoprint.plugins.softwareupdate - WARNING - Could not check octoprint for updates due to a network error
2019-10-07 17:37:28,285 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2019-10-07 17:38:20,511 - octoprint.plugins.announcements - ERROR - Could not fetch channel _important from https://octoprint.org/feeds/important.xml: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/important.xml (Caused by ConnectTimeoutError(<urllib3.connection.VerifiedHTTPSConnection object at 0x712ec090>, 'Connection to octoprint.org timed out. (connect timeout=30)'))
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements/__init__.py", line 355, in _get_channel_data_from_network
r = requests.get(url, timeout=30)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/adapters.py", line 504, in send
raise ConnectTimeout(e, request=request)
ConnectTimeout: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/important.xml (Caused by ConnectTimeoutError(<urllib3.connection.VerifiedHTTPSConnection object at 0x712ec090>, 'Connection to octoprint.org timed out. (connect timeout=30)'))
2019-10-07 17:38:20,534 - octoprint.plugins.pluginmanager - ERROR - Could not fetch plugins from repository at https://plugins.octoprint.org/plugins.json: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /plugins.json (Caused by ConnectTimeoutError(<urllib3.connection.VerifiedHTTPSConnection object at 0x712d8dd0>, 'Connection to plugins.octoprint.org timed out. (connect timeout=30)'))
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager/__init__.py", line 784, in _fetch_repository_from_url
r = requests.get(repository_url, timeout=30)
ConnectTimeout: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /plugins.json (Caused by ConnectTimeoutError(<urllib3.connection.VerifiedHTTPSConnection object at 0x712d8dd0>, 'Connection to plugins.octoprint.org timed out. (connect timeout=30)'))
2019-10-07 17:38:50,563 - octoprint.plugins.announcements - ERROR - Could not fetch channel _releases from https://octoprint.org/feeds/releases.xml: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/releases.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x71253550>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
ConnectionError: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/releases.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x71253550>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
2019-10-07 17:38:50,581 - octoprint.plugins.announcements - ERROR - Could not fetch channel _blog from https://octoprint.org/feeds/octoblog.xml: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/octoblog.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x712d8df0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
ConnectionError: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/octoblog.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x712d8df0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
2019-10-07 17:38:50,598 - octoprint.plugins.pluginmanager - ERROR - Could not fetch notices from https://plugins.octoprint.org/notices.json: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /notices.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x712d8130>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager/__init__.py", line 834, in _fetch_notices_from_url
r = requests.get(notices_url, timeout=30)
ConnectionError: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /notices.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x712d8130>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
2019-10-07 17:38:50,607 - octoprint.plugins.announcements - ERROR - Could not fetch channel _plugins from https://plugins.octoprint.org/feed.xml: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /feed.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x712d81b0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
ConnectionError: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /feed.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x712d81b0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
2019-10-07 17:38:54,588 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.1.252', 1900), not sending a M-SEARCH reply
2019-10-07 17:38:57,713 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.1.252', 1900), not sending a M-SEARCH reply
2019-10-07 17:39:05,912 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.1.252', 1900), not sending a M-SEARCH reply
2019-10-07 17:43:00,288 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.1.252', 1900), not sending a M-SEARCH reply
2019-10-07 17:43:01,670 - octoprint.plugins.discovery - WARNING - Can't determine address to user for client ('192.168.1.252', 1900), not sending a M-SEARCH reply
2019-10-07 17:52:14,769 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-10-07 17:54:49,042 - octoprint.startup - INFO - ******************************************************************************
2019-10-07 17:54:49,045 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2019-10-07 17:54:49,045 - octoprint.startup - INFO - ******************************************************************************
2019-10-07 17:54:50,480 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-10-07 17:54:53,216 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-10-07 17:54:53,353 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-10-07 17:54:53,407 - octoprint.server - INFO - Intermediary server started
2019-10-07 17:54:53,410 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-10-07 17:54:54,012 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-10-07 17:54:54,057 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-10-07 17:54:54,059 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-10-07 17:54:54,126 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-10-07 17:54:56,416 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-10-07 17:54:58,044 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-10-07 17:54:58,046 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-10-07 17:54:58,046 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-10-07 17:54:58,053 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2019-10-07 17:54:58,063 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
2019-10-07 17:54:58,086 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
