Im trying to set up Octoprint& Klipper on my ender 5. I followed the EB3D Printing youtube video. Klipper and OctoPi is flashed, Octoprint is running, Made all the changes to the config files.
OP reports "Klipper State: Ready"
If I click on anything except "Restart Host" or "Restart Firmware" the new window pops up, but the entire screen gets dim and stops responding.
For example if I click "Open Klipper Config", I get this.
I can scroll my mouse wheel and the Octoprint screen scrolls behind the pop up box, but I cant click anything. The pop up config box stays locked and doesn't scroll. I can see the text of the config file.
It does this with everything I click.
I cant open the log file, I cant really do anything.
I tried a different browser with the same results.
The only thing I can do is reload the UI.
Im stumped, Any suggestions?
Thanks for the suggestion but I already tried all that.
Cant access safe mode, screen goes grey & I cant click
The recovery page loads and I can click all the options...when I try to open safe mode it disconnects from server and reconnects (as it should), but then nothing. it doesnt open a new octoprint session from the recovery page. Rebooting does the same.
I dont have any working backups to recover from because this is my first attempt at Octoprint/klipper
I cant connect to my RPi via WinSCP or Putty, all I get is repeated network timeout.
Is this a wifi problem? I was able to connect instantly last night, which is how I was editing the config files
EDIT: Nevermind, I discovered that the IP address changed since last night, now I can connect via WinSCP & puttty
